Old 26-05-2012, 05:32 PM   #1
M4CO
M4CO's Avatar
Default Problem filling up petrol
Went to the petrol station to fill up my car when i saw petrol was only $1.38 haha....i had about three quarters full but when i started filling it only took a couple of liters and started to click as if it was full but i know it can't possibly be full (got back in the car and needle hadn't moved) so i went and paid and moved to the next pump thinking there might be something wrong with the pump but the same thing happened?? anyone had this happen before
M4CO is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 05:38 PM   #2
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
Default Re: Problem filling up petrol
its all to do with the angle you are holding the knobmake that nozzle. move it to different angles in filler cap and should be good to go
FG XR8 Ute 2010 Nitro,
Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum
Powerbond 25% under drives, Sports bar,
now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset
total of 285.5 rwkw and 642nm
when Herrod cams in 290rwkw
GSXR 750K7 with goodies, dyno'd 136rwhp,
10.567sec for the strip
comagutsa is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 05:41 PM   #3
M4CO
M4CO's Avatar
haha yeah tried it every which way but still didn't want to fill
Old 26-05-2012, 06:23 PM   #4
XR6T0Y
Half brain dead already
XR6T0Y's Avatar
I've noticed it too. I can squeeze nearly an extra 15$ into mine. And still only gives me 550k's per tank haha
"My Shockwave Baby"
Running tuned at 191.3rwkw with 475nm Torque
Pacemaker PH4490 + Hiflo Pacemaker cat/catpipe + Xforce 2.5' catback into dual pipes after Diff.
FG Manifold + Herrod airbox + 20% underdrive +Hi flow thermostat + 26mm radiator and Weapon X coils!
Now rolling on staggered Matte black Lesnso D1R's
NOW MANUAL!
Shockwave Blue!
More to come
Now the proud owner of a '97 NL Fairlane
XR6T0Y is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 06:54 PM   #5
XR Martin
XR Martin's Avatar
My EL was a royal pain to fill up when I bought it. Eventually got sick of it and took a peek down the filler, saw that the little flap had broken and was creating an obstruction in the tube. Tried pulling it out with one of those flexible claw things, got a hold of it but it fell into the tank.
Now theres no obstruction and it fills up fine.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 07:01 PM   #6
I reckon
I reckon's Avatar
put a bit of hair around the hole!
I reckon is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 07:04 PM   #7
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
I notice that after service stations have their pumps serviced, the splash back cut off is sensitive.
What i do is start off slow to get rid of any warmth in the nozzle, as colder fuel flows through the
splash back gets less sensitive.
Try it and see..
jpd80 is online now   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 07:21 PM   #8
M4CO
M4CO's Avatar
yeah i had a peak at that when i was filling up looked like it was fine, opening and closing properly
hahahah
Try it and see..
oh ok thanks
Old 26-05-2012, 08:46 PM   #9
Dr Smith
I pretty much go to the same pump at the same petrol station around 10:30pm usually because that's when the wife asks me, "by the way will I get to work and back with 40km till empty?" ..obviously not...and I can only fill up the G6ET by starting slowly as jpd80 stated and holding the nozzle almost horizontal. don't ask why but it's how it works.
Dr Smith is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 09:28 PM   #10
Silver Ghia
Silver Ghia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: As Silver Ghia his contributions to the AU and BA technical areas have been of high quality and valuable to the member base.
Generally turning the handle anticlockwise to around the 3 to 4 o'clock position works.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 02:55 AM   #11
MWTB
I'm old and I fell
MWTB's Avatar
^ This.
The general consensus with the fuel filling issues like this is to hold the nozzle at 4 o'clock. I personally don't get this problem, not sure why I'm the lucky one, but it seems to work for others!
BF2 XR6 turbo
82lb injectors, Walbro fuel pump, bigger cooler, Plazmaman piping, SS Growler, tune, ZF tune, Crow valve springs so far.
Ozracing coilovers, Pedders sway bars front and rear.
315rwkw
MWTB is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 02:02 PM   #12
superfly
Go the Hogster!
superfly's Avatar
In my old WRX, I had to pull the nozzle out a bit otherwise it would keep stopping (same happens on my wife's WRX) but with the XR50, I just stick it in and it fills up no problems. First click and it is full. With both WRX's after the first click, I can still get in another dollar's worth. But not with the XR50. It starts overflowing if I fill after first click.
Nitro XR50 - the last brand new one in OZ
first registered Oct 2011.
superfly is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 02:52 PM   #13
M4CO
M4CO's Avatar
Went to fill it up again today and it filled properly?? Hopefully it was a one time thing but thanks for the tips will try them out if it ever happens again!
Old 27-05-2012, 02:57 PM   #14
Franco Cozzo
Franco Cozzo's Avatar
My EL is a real bastard to fill up, it takes like 20 minutes to try fill it up because it keeps clicking off.
Old 28-05-2012, 09:13 AM   #15
aussie muscle
aussie muscle's Avatar
i have to go slow when filling the BF. it's a real pain. bzzt, click, bzzt, click. sometimes rotating works, sometimes pulling out a bit works.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 12:11 PM   #16
mytgxl
mytgxl's Avatar
I would laugh at this but my Ef Fairmont was a real pain in the hineny to fill up had to put it in slow otherwise it would click off all the time! near ten min fill a tank! But a tree solved the problem! lol Have no problems with the BA.
Never drive faster than your guardian angle can fly but fast enough so the devil don't catch you!
mytgxl is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 01:46 PM   #17
Feathers
Lucifer's Angel
Feathers's Avatar
I've been having this problem with the diesel pumps at the servo we use for work.
Trying to fill a nearly 200L tank makes me want to cry.
SINISTER BA XR6
Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford...
It's being beaten by a girl driving a Ford
Feathers is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 04:01 PM   #18
Terror_Tree
SZ II TS Territory-Black
Terror_Tree's Avatar
I have had the same problem in my Territory and the fuel would splash back at my local BP, but only I used the premium pumps, I tried the normal ULP pump and it worked fine. A couple of people have told be the cutting off and splash back is because the flow is too fast.
Kick it in the guts Barry!
FWD is the Devils work
Terror_Tree is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 04:16 PM   #19
RedHotGT
Long live the Falcon GT
RedHotGT's Avatar
Originally Posted by aussie muscle
i have to go slow. it's a real pain. bzzt, click, bzzt, click. sometimes rotating works, sometimes pulling out a bit works.
EDITED
We're talking about filling up petrol - right?
RedHotGT is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 10:01 PM   #20
saam
saam's Avatar
What ive noticed at some servos is that when petrol is selling at a discounted price, the flow seems to be slow
But when petrol is selling at the full retail price, the flow is twice as fast
Go figure ......
saam is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2012, 08:18 PM   #21
Kevaclone
Kevaclone's Avatar
Go figure ......
Perception is a funny thing isn't it?
03 BA XLS 6cyl Ute-Mercury Silver
04 Subaru Liberty GT Premium
99 Toyota 105 series Cruiser TD
99 5.8M Profish plate alloy carport decoration
Kevaclone is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 09:14 PM   #22
SIMBAD
RAPID GT-P
SIMBAD's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This thread: BA-BF diff cradle removal for diff bushes
if u hold the nozzle upside down it will not click and carry on.
but be warned, it wont click off once full.
Full Difilippo big boy exhaust /4.5" body ballistic metal cats / boss 315 plenum & twin throttle body coupled to bpr airbox / powerbond underdrives / herrod 290 cams / malwood opt 3+ / hrs Pegasus rims 19x8.5 front - 9.5 rear / nitto invo 245-35-19F & 275-35-19R / whiteline swaybars/ Under bonnet bling / 4.11 harrop truetrac
Enhanced by BLUEPOWER
supercharged 363 dart takes on au work ute http://fordforums.com.au/showthread.php?t=11342906
SIMBAD is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2012, 05:24 PM   #23
Kevaclone
Kevaclone's Avatar
Really???
it will click off no matter what way you hold it, if it doesn't it is faulty and will repaired once someone complains when they are covered in petrol
