Old 25-03-2007, 09:49 PM   #1
XRated
Shoot.
XRated's Avatar
Default Removing 1997 Navara door-trims
Sorry for another non-Ford thread.... I couldn't find a Navara forum :P
I'm trying to help a friend remove some speakers from his '97 Navara. Basically we are having trouble removing the window winders and that is the only thing stopping us from getting the door trims off. Is there a certain trick to it? Or does anyone know a forum that can help?
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2007, 10:53 PM   #2
Psycho Chicken
Psycho Chicken's Avatar
http://www.outerlimits4x4.com/viewfo...c39e3f1ecb9698
Mostly Patrols but someone might know.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2007, 10:58 PM   #3
Interceptor
HSV - I just ate one!
Interceptor's Avatar
they've for a C clip on them like the old holdens did, needs a special tool to remove the clip, but other than that they're **** easy
when you replace the handles, just pop the clips all the way into place, make sure you've got the handle in the right spot and give the handle a whack!
Old 25-03-2007, 11:02 PM   #4
bodes-sh
you can also get them off easily with a flat head screwdriver. Just push the trim in around the where the winder goes into the door, and look in, then just push it off
Old 25-03-2007, 11:38 PM   #5
dave351cid
playing in my big shed
dave351cid's Avatar
being a nissan the clips will probably be facing away from the handle ( the open side of the circlip will be on the side away from the winder handle) watch when it comes off that it dosnt fly off somewhere and be lost. ( they are called jesus clips, when the fly off you say "jesus christ- where did that go ")
if you dont have the proper forked shape tool you can use a thin piece of wire with about a 3mm L shaped bend on the end to hook in the back of the clip, or a small screwdriver to push the clip from the front , or a piece of rag and pull it around the handle so it goes into the gap between the doortrim and the handle and catchs the clip pulling it off.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2007, 12:19 AM   #6
XRated
Shoot.
XRated's Avatar
Damn, you guys are awesome! I didn't expect a reply so soon.
Many thanks, I'll send him on the info and have a look myself if he doesn't understand it (most-likely :P).
20V Turbo
