Old 30-08-2011, 12:59 AM   #31
sudszy
Default Re: 2089kw German Factory Supercar WTF ?
Originally Posted by XR6menace
LOL from elsewhere...
0 to 100km/hr in 0.9 seconds would take an acceleration of 30.9 metres per second squared (3.2g).
For a 1000kg car this is a launch force of 30,900 Newtons. For a slick tyre in the dry the maximum friction factor is 0.9.
The maximum launch force available for a 1000kg car on slick tyres in the dry is about 0.9*1000*9.81 = 8829 Newtons.
The fastest 0-100km/h time for this 1000kg car is therefore 3.2 seconds.
It would have to weigh nearly 3500kg to accelerate to 100km/hr in 0.9 seconds. Try going around a corner in that tank.....
Return comment ...
0.9 friction lol.
Top fuel cars get to a hundred miles an hour in a car length and under a second so they must weigh FOUR HUNDRED TONNES. What sort of stupid are you?
Yes, both comments miss the mark.
Drag cars have tyres with coefficients of friction in the 2-2.5 range, 0.9 is ultimately just a high performance passenger car tyre. If the drag car was powered by an electric motor of the same power(we are talking 2000hp+ here), it would be be only able to achieve ~half the acceleration of one with a fuel motor.
Reason being: the vertical thrust from the exhaust gases of the fuel motor provide enough thrust to ~double the force over the back wheels, doubling the force that the tyres can provide before slipping at launch, but not having to accelerate double the mass, hence getting the accel into the 5g region.
so 100km/h in 0.9 secs, requires 3.2g of accel or tyres with coefficient of friction of 3.2(nope they dont exist), and unless the thing has some pipes pointing skywards, I say hoax, or perhaps its got a jet or rocket engine attached!
sudszy is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 04:07 AM   #32
Falc'man
You dig, we stick!
Falc'man's Avatar
I'm not sure it has enough power to get to 600km/h let alone in 7 seconds.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 07:23 AM   #33
Bad Bird
Watts a panhard.
Bad Bird's Avatar
Red Victor achieves similar acceleration numbers. I'm not sure that I'd want to go around corners with the baggy, soft tyres and drag setup suspension though.
I don't have low self-esteem. I have low esteem for everyone else.
Bad Bird is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 08:08 AM   #34
ltd
Force Fed Fords
ltd's Avatar
It would have to be powered by something like this where acceleration is not dependant on the ability of the tyres. http://www.youtube.com/watch?v=waDeveWle54
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 12:01 PM   #35
RedHotGT
Long live the Falcon GT
RedHotGT's Avatar
Believe it when I see it
RedHotGT is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 12:05 PM   #36
Professor Farnsworth
Fossil fuel consumer
Professor Farnsworth's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
ok i'll say it, 0-600 in 7 seconds is absolutely impossible.
Absolutely, undeniably impossible.
Let alone the fact that the driver would probably grey out under full throttle like a fighter pilot and wrap it around a tree
2023 Superb Sportline - Steel Grey
2024 RS 3 Sedan - Mythos Black
2024 Mustang GT - Vapour Blue (built 31-10-2024 - waiting for ship)
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 06:11 PM   #37
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
http://news.drive.com.au/drive/motor...829-1jhw3.html
World's greatest hypercar hoax?
Matt Campbell
August 29, 2011
RSC Supercar Concept
German brand says it will build a car with 2089kW of power, 3494Nm of torque and a 0-600km/h time of seven seconds.
There are fast cars. There are powerful cars. And then there’s this.
German company RSC says it is working on a hypercar that has a claimed 0-600km/h time – yes, 600km/h – of 7.0 seconds. It can also apparently get to 300 km/h in the same amount of time it takes a Nissan GT-R or Porsche 911 Turbo S to get to 100km/h.
RSC has reportedly been working on its upcoming radical racer since 2009, with a concept version of the car set to be unveiled at the Top Marques Monaco automotive expo in April 2012. So far, however, the brand has released just one teaser image of the new vehicle.
Advertisement: Story continues below
The RSC website states the car will be powered by a 5.2-litre, quad-turbocharged, eight-rotor rotary engine producing 2089kW of power and 3494Nm of torque – or roughly five times the power and torque of a 911 Turbo S.
The site’s specifications sheet claims the engine will be mounted behind the seats, with power sent to all four wheels via an eight-speed automatic transmission.
With such dramatic claimed outputs, it comes as no surprise that RSC is boasting some eye-wateringly quick sprint times, too, including a bottom-blistering 0-100km/h time of just 0.9 seconds.
According to the website, the car will make it to production late in 2012, with a maximum of 12 units per year allowing the brand to “fulfil our high pretence to exclusiveness”.
This isn't the first time RSC has boasted about a car that hasn't yet been seen in the metal. Earlier this year the company touted its first effort, the Predator GT, which was said to be capable of 883kW of power and a 0-100km/h sprint time of less than 3.0 seconds.
If RSC's claims about the new car - which is believed to be an evolution of the Predator GT - are true, then it should easily eclipse the current record for the fastest production car held by Bugatti's Veyron Super Sport (431.07km/h).
We’ll believe it when we see it.
Old 30-08-2011, 07:13 PM   #38
mrghia
mrghia's Avatar
so i should be able to buy this the drag top fuel cars then?
mrghia is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 07:22 PM   #39
mickyyyy
To make that power it would need 4 GT42 turbo's
Hard for me to see this being streetable and it defiantly won't reach those 0-100km figures
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 09:05 PM   #40
Bossxr8
Peter Car
Bossxr8's Avatar
I think the car in the "secret" picture is a Ferrari 458. Look at the headlights and their positions in location to the guards. And the rear view mirrors. Or possibly a Gallardo.
Old 30-08-2011, 10:07 PM   #41
Mechan1k
Mechan1k's Avatar
On an unralted note ... saw one of these ^^^^^^^^^^^ cruising around Ferrers Rd Eastern Creek the other week. Droolworthy indeed.
Old 31-08-2011, 08:21 AM   #42
prasac
prasac's Avatar
it's possible, Mike Moran built a 3000hp quad turbo motor over 5 years ago.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2011, 11:27 AM   #43
Brent
Would be interesting on a wet road........
Brent is offline   Reply With Quote Multi-Quote with this Post
