Old 28-08-2012, 09:41 PM   #1
XARATE
XARATE's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Quality contribution which has gone somewhat un-noticed so far.
Default Looking for the owner of OZGRNT. White AU XR8 ute
Just trying to get in contact with the owner of a white 2001 AU XR8 ute that passed through Tumut recently, i believe he works in melbourne.
The reason why im trying to contact him is he broke down while he was near tumut. The lpg system failed and i removed the wiring and lpg module as it was unrepairable, after removing the wiring i took it for a quick drive to make sure it was driving fine, but i ran into a problem. It seems that at one stage the wiring for the drivers side 02 sensor was jammed between two brake line to secure it, upon removing the lpg wiring i unknownly disturbed the wiring causing the 02 sensor plug to sit on the exhaust and melt during the test drive.
I feel really bad about this, i hate damaging someone elses pride and joy, even moreso when i was unable to fix it as i didnt have a replacement sensor. The wiring itself was ok and everything was still operating correctly but i want to make sure it didnt fail or cause dramas on his trip home. If possible i would like to repair it free of charge when im in melbourne next.
If anyone can put me in contact with him i would appreciate it
270rwkw BA XR8
http://www.fordforums.com.au/showthread.php?t=11339147
XARATE is offline   Reply With Quote Multi-Quote with this Post
