Old 19-12-2012, 01:35 PM   #1
Richstang
Default Car trailer design
Looking to build a simple single axle car trailer to move around pre 70s falcons/mustangs (Rolling shells).
Currently have a old caravan chassis, its 50 x 75 x 3mm drawbar and main rails, nice and strong with good brakes and strong solid drop axle. Was making into a open cage trailer but now considering making it into a my car trailer.
Its problem, only 1425 inside to inside rail.
A 68 falcon, how wide is it from outside edge of each wheel?
Richstang is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2012, 02:57 PM   #2
kempy311
BEN
kempy311's Avatar
Default Re: Car trailer design
Think you will need a tadem.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2012, 07:46 PM   #3
xtremerus
FG XR6T trayback
xtremerus's Avatar
Single axle should be OK for just rolling shells.
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2012, 12:05 AM   #4
xisled
Get a tandem trailer so much easier and built for the job.
xisled is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2012, 07:31 AM   #5
LTDHO
The one and only
LTDHO's Avatar
I wouldn't go for single axle either.
Speak to a provessional shop (Melbourne trailer and carravan supplies for example) Chris there knows his stuff.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2012, 01:17 PM   #6
Richstang
How many caravans do you see on the road 16", 17" foot long just with single axle? these vans once with all supplies, water and other holiday junk on board would weight a LOT more than a rolling shell?
Old 20-12-2012, 01:30 PM   #7
poppa smurf
poppa smurf's Avatar
you need to have your GTM for your axle load.......axle load varies quite substantially
I run 1850 kilos plus on a single axle, 18'6" caravan.....time she's loaded I probably push close to 2 tonnes or better
no way of telling what you can legally carry without knowing your GTM or doing complex sums dependent on axle thickness and so on......the caravan feller may give you ballpark figures but I really dont know how you could come up with a GTM
then I think you still need to have this certified and stamped or tagged somewhere
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2012, 01:43 PM   #8
XP6
Formerly ST170ish
XP6's Avatar
The main difference to a caravan is not the weight capacity but the balance of the load, a car trailer needs to have a wide balance center point to allow for nongs who can't load for ####... you know they have the tow car popping a wheelie.
Most cars are only designed for 100kg weight on the tow hitch/ball.
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2012, 02:27 PM   #9
poppa smurf
just to complicate matters a bit further the original design of the caravan had the axle placed in such a position so as to Balance out the ORIGINAL design of the caravan
kitchens in front usually meant the axles were placed further forward, kitchen to rear axles further to the rear.....this may have only been millimetres but it all counts......last I heard Jayco had around 4 placements for axle position depending on layout
if it is an older design the axle may just be placed central or maybe a little forward of centre.....ball loading and carrying capacities weren't that important in the "old days".....we just hooked up and went
there would be some serious calculations necessary before placing anything on it......then there is ball weight, weight distribution hitches, electric brakes
you have some fun ahead
Old 20-12-2012, 08:22 PM   #10
LTDHO
The one and only
LTDHO's Avatar
WTF????
When did I say anything about weight?????
