11-10-2021, 04:58 PM | #1 | ||
Just a heads-up, it looks like Bunnies are getting out of capillary fittings. Lots of stuff gone, many brass fittings set to 99¢. Hopefully they’ll write their silver solder way down, too.
11-10-2021, 05:35 PM | #2 | ||
Haha. I was in a Bunnings last week and overheard this doddery old bloke ask more than one Bunnings' employee where the silver solder was as he couldn't see it (left his glasses at home). All I saw him get was blank stares.
11-10-2021, 06:37 PM | #3 | ||
That was probably CB
jaydee351 4DV8 |
11-10-2021, 08:07 PM | #4 | |||
This may be the reason:
https://www.9news.com.au/national/le...f-c2dcc3f9279d Quote:
https://www.msn.com/en-au/news/austr...er/vi-BB1g3GMQ So perhaps it's time to get better acquainted with Pex or SmarteX-C Push-Fit type fittings.
regards Blue Last edited by aussiblue; 11-10-2021 at 08:36 PM. |
4 users like this post: |
11-10-2021, 09:03 PM | #5 | ||
Interesting, press fittings are still the norm in most new work up to at least 50mm. I’m in with the “plastic is rat food” believers. Damage a copper line incidentally, hammer it flat in seconds to stop or at least staunch the flow. Try that with PEX.
11-10-2021, 09:30 PM | #6 | ||
Agreed the SmarteX-Press fittings would be preferable. But using something like these https://www.ebay.com.au/itm/18427025...cAAOSw--1fEURM or https://www.ebay.com.au/itm/39249367...cAAOSwgsddrrvv instead of https://www.bunnings.com.au/ridgid-p...-jaws_p0170587
regards Blue |
11-10-2021, 09:30 PM | #7 | ||
I never use presoldeted capillary fittings myself, just the bare copper silver soldered. I don't like the idea of lead with drinking water.
11-10-2021, 09:42 PM | #8 | |||
regards Blue |
11-10-2021, 09:58 PM | #10 | |||
Experienced Member
If I had to build a new dwelling copper will be not used again. |
11-10-2021, 10:05 PM | #11 | ||
That usually happens not far downstream of contact with something like a section of galvanised steel. Yes, a good chunk needs replacing when it goes bad like that!
11-10-2021, 10:08 PM | #12 | ||
Good luck with getting silver solder on special.
Last time I found it in tools area, more secure with more cameras etc. Regards, George V |
11-10-2021, 10:29 PM | #13 | |||
regards Blue |
11-10-2021, 10:34 PM | #14 | ||
Yes, the subdivision is from 1947, so getting on. Potable water was serviced in the area from around 1910, and just extended.
It was built “sewer ready” but unsewered - grey water went into the drains, then to the creek. Cans were used for a few years, then the sewer went in - not all the grey water lines were picked up, and a few of them were unknowingly converted to sewer by renovators. |
11-10-2021, 10:36 PM | #15 | ||
Where to next??
Wasn't he in one of the Marvel movies?
11-10-2021, 11:39 PM | #16 | |||
BANNED
Been there done that...just fold it on itself...cable tie and flow stops. or cigarette lighter till she melts and plugs itself....try that with copper...LOL Best part about Bunnings smartex is a 200mm shifter and press..connections come clean off and can be reused. Only copper I use these days is the shower breach, even then I mate the tails to smartex onnections....best thing since sliced bread. Bye bye overpriced plumbing..
Please press the "Like" button if you enjoy my posts. (It's the red triangle with exclamation mark on the left) |
12-10-2021, 07:28 AM | #17 | ||
Bolt Nerd
I’d never heard of PEX before moving here…
Our main house (8yrs old) is all PEX… Magic stuff! UV is it’s enemy though! There was a section of PEX connecting h/water to outside kitchen downstairs… someone had used duct tape to protect from sun.. unfortunately, tape perished leaving tube exposed. A month later it burst (brittle as glass) Hellova time buying pex or crimp rings here! Ended up ordering through Amazon.. 20 metres tube, fittings, crimp rings and crimping tool. You can also use “sharkbite” fittings which are push in.. No tools required. The older house (20yrs) is all 1/2 glued PVC as is the norm here! (Even mains are glued pvc sched 40) Even corner supermarket & gas station sells pvc fittings & glue. Big downfall with Tico pvc repairs is they’ve never heard of primer, so joints continually blowing apart!
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
12-10-2021, 08:42 AM | #18 | ||
Big dramas here few year back at the now completed Perth Children's Hospital, caused by cheap Chinese brass plumbing fittings, loaded with lead, and all removed after completion, see if I can load link, I also think that's why plastic is the go to for fittings now?
https://www.abc.net.au/news/2017-08-...e=abc_news_web |
12-10-2021, 10:27 AM | #19 | |||
3 users like this post: |
12-10-2021, 04:30 PM | #20 | ||
Cabover nut
Good stuff, Sharkbite and Made in the USA. Did my whole place using their stuff. Certainly nothing like that cheap crap the big green shed of Chinesism sell.
20-10-2021, 01:59 PM | #22 | ||
There’s clearly a big push to PEX this year. Even many “standard” copper plumbing products are less available, such as lagged coils. I wonder if domestic AC will change materials for paircoil?
20-10-2021, 04:20 PM | #23 | |||
I think split bashers might go for that eventually, especially if they're flaring back to back splits. The big issue is field repair brazing is so easy with copper. I knew some installers that always brazed even split systems as they never liked flares. I know even more that couldn't do a leak free flare to save their life anyway. Another issue is refrigerants always changing, who knows if aluminum can withstand the pressure or not react badly to whatever refrigerant comes out next? Copper is always a safe bet and would always be used on larger systems. E: Found this in artick paper as of 2019, seems copper is needed for good old A.S. holding us back/to ransom Last edited by oldel; 20-10-2021 at 04:25 PM. |
