#271 | |||
Ich bin ein auslander
Growing old is compulsory, growing up is optional! |
#272 | ||||
Nutty Professor
And I didn't lift off the throttle as soon as I hit the water, I lifted after I heard the engine rev up and glanced at the wildly optimistic speedo. You don't need to give a physics lesson to a nutty professor mate. Flappist - if you feel the need to launch personal attacks on me for whatever reason, may I kindly request that you PM them to me so that I can ignore them and they don't fill the thread with useless crap. BA Falcon - if you don't like it don't read it ya clown. This was intended to be a civilized debate between enthusiasts. I will concede that the thread was poorly titled and has degraded a little since the start, but seriously, ace it up a bit mate.
#273 | ||
How about we all put our differences aside and go have a beer
#274 | ||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
Back to the original idea in the original post.
I can't see it happening with a transverse iron block straight 6. I'd like to see the block as some of the following: a stressed member a flat "boxer" engine a smaller capacity high boost engine it would have to be good handling straight off the bat. Porsche & Alpine spent years fiddling with tricky layouts to get them right. Get it wrong and the car would risk being labelled "a Corvair for the noughties" (yup, I know that the Corvairs were rear engined). Shudders at thought of big, heavy Boss 290 in mid/rear of normal car (& they are done in GT40 replicas & Ford GT's). If it was a transverse mid engine there are meant to be some nasty torque multiplication factors when you get off and on the throttle and you've still got to have space to hang a transmission of the side. If you are running a front mounted radiator you'd need to have somewhere for the hot air to go before it hits the (presumably) front mounted luggage space. The back tyres might want to be wider (to ease the strain on the DSC) and that's going to take up a bit more of your space between the rear hubs. The weight of the front mounted fuel tank and any luggage would vary a bit, but a smart stability control system might be able to fiddle things to help it. Some 911s have reputations for understeering under brakes in the wet. Gicotollo's had Alfa Sprint shells with mid-mounted Alfa V6's then Holden V8's in them. But it was a lot of work, including new suspension arms.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ |
#275 | |||
FORMERLY TX3DUDE
(best of both worlds?) |
#276 | |||
This incident, I am sorry to say is not the shortfall of the drivetrain layout, just the method of control delivery behind the wheel. As for nutty professor, why do you have so much trouble understanding vehicle dynamics?
#277 | |||
#278 | ||||
Nutty Professor
#279 | ||
I've received enough reported posts warnings from this thread to call it a day.
Now closed. It's run it's course.
