Old 04-03-2014, 02:57 PM   #31
Wretched
Render unto Caesar
Wretched's Avatar
Default Re: BMW will become the first car maker offer advanced laser headlamps
Originally Posted by Big Damo View Post
That's like everything though on European cars, pain in the *** to work on but when everything is working as intended its fantastic.
I disagree, changing a light globe in the LT focus is a simple removal of a couple of screws and slide out the light assembly. In the BA/BF Falcon the battery had to be removed along with 3 fingers. A total design disaster.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson
Wretched is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2014, 03:21 PM   #32
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Funny how things are worked out... The Festiva was ultra easy, pull the rubber boot off the back of the light, unplug wire, remove globe and your done.
Focus... can't really complain. Light has to come out, but once you have done it a few times it is pretty easy...
When you hear of bumpers being removed to change batteries and lights and several hours labour along the way...
Guy at work has a new Golf... new battery is a real pain apparently. Several hundred dollars, half for the battery, half for the labour!
___________________________
Old 04-03-2014, 11:38 PM   #33
csv8
csv8's Avatar
WQ Fiesta remove front grill to get at one screw to get headlight out to change globe !!!
CSGhia
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2014, 10:16 AM   #34
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Same with my LV Focus, but there are other things on it which will be a pain in the *** when the time comes, alternator and starter motor spring to mind judging by their locations.
Old 05-03-2014, 02:32 PM   #35
bungarra
Never had an issue with the BA Wagon I had. Just turned weels full lock to the opposite side to the globe I was changing and come in from the wheel arch. Learnt that from a Ford mechanic.
bungarra is offline   Reply With Quote Multi-Quote with this Post
