26-10-2012, 01:51 PM | #91 | ||
The suggestion that OHC is modern technology is laughable...check the history books.
OHV vs OHC - positive and negatives for both. On V and flat configurations OHC can present packaging issues. Inline engines not a major problem. When it comes to variable cam timing & multi valves OHC has the advantage, its a bit harder to control exhaust and inlet timing independantly with a single cam. Its great GM is sticking with push-rods, another easy-fit option for resto-modding something old. |
26-10-2012, 03:01 PM | #92 | |||
Just to think I almost ended up buying an old 5L VS. |
26-10-2012, 03:16 PM | #93 | ||||
The Silver Bullet - BJ74 Where the actions at Ontrack 4wd Club https://www.facebook.com/ontrack4wdclub |
26-10-2012, 03:46 PM | #94 | ||
We're talking street cars remember...
As long as it's reliable, as efficient as possible (given that an internal combustion engine is pretty hopeless anyway at efficiency of turning fuel into motion), and easy and cheap to build with a long service life, who cares what method goes on inside it? Pushrods do have definite advantages that OHC and especially DOHC just can't match when it comes to packaging...that photo of the Windsor compared to the modular engine was simply staggering...I had no idea. You can have multi-valve engines with pushrods. You simply have a fork shaped rocker arm being pushed by a pushrod and two valves being opened by the "fork" on the other side. |
26-10-2012, 04:03 PM | #95 | |||
Ploppy pants
There was a set of multi-valve heads floating around years ago for the LS1....don't know if it ever got off the ground.
Don't wait to be told.....you need Palmolive Gold!! |
26-10-2012, 05:00 PM | #96 | |||
26-10-2012, 08:54 PM | #97 | ||
26-10-2012, 09:04 PM | #98 | |||
Straight Eight
Big engine is BIG!
The Falcon is dead. Long live the Mighty Falcon. |
26-10-2012, 10:54 PM | #99 | |||
GM have build a kick **** engine that happens to be push rod and you have attacked this instead of appreciating the achievement All ford forum members love fords there is no doubting that What some of us also understand is that this forum is also for the appreciation of all things automotive and that things of beauty come in other shapes and brands At the end of the day a great car or engine is just that , regardless of who it is made by So instead of bagging anything that doesn't have a blue oval badge on it why dont you start appreciating the fact that we have engineers that still want to build power house engines that are massed produced putting them with in reach of a lot of the motoring public whether they be chev , ford or Chrysler If you still think the engine is crap and feel strongly about that i suggest you send an email to GM in Detroit and after you detail your engineering and design qualifications and all the development work you have done on engines over say the last 10 to 15 years, I'm sure they will be interested in what you have to say Last edited by neptune blue; 26-10-2012 at 11:15 PM. |
26-10-2012, 11:20 PM | #100 | |||
27-10-2012, 01:07 AM | #101 | |||
Straight Eight
27-10-2012, 01:59 AM | #102 | ||
Call me dirt... Joe Dirt
Is it easy to get to the cam shaft on the LS motors? A lumpier cam seems the first mod for a lot of owners.
Whatever the pros/cons of pushrods, it seems these motors respond more for less $$$.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
27-10-2012, 05:44 AM | #103 | ||
should go ok in a 1500 kg corvette, well see how it turns out for reliability when we actually see one.
27-10-2012, 06:12 AM | #104 | |||
Grange killer!!!!
GM still living in the past - Coyote will kill it!!!
INSURED BY MAFIA. YOU HIT US, WE KILL YOU! FORD FTE AU T-SERIES CLUB OF AUSTRALIA
www.tseriesclub.org |
27-10-2012, 07:12 AM | #105 | |||
27-10-2012, 07:44 AM | #106 | |||
27-10-2012, 08:46 AM | #107 | |||
Any SC owner will still be hunting F6's if they're looking for a decent fight. FPV could easily rub salt into the wound by kitting 2013 SC FPV's and F6's out with R Spec hardware and software as standard kit |
27-10-2012, 08:46 AM | #108 | ||
Performance moderator
TOHC is fine but Ford sort of got it wrong with heavy cast Iron engine with long stroke that they didn't let it rev..
Cobra heads on a truck block !! May as fit them to an old Y block..
27-10-2012, 09:22 AM | #109 | |||
[SIGPIC][/SIGPIC]
27-10-2012, 09:24 AM | #110 | |||
many in thread are mentioning it as potentially the next HSV engine
[SIGPIC][/SIGPIC]
27-10-2012, 09:32 AM | #111 | |||
but it's not a "great engine" it is using technology long abandoned by the automotive community as antiquated and inefficent, I'm not against push rods in old school cars but this is the 21st century it is time to move on to modern technology.
sure crude OHC is older than OHV but OHC has been developed into something OHV could dream of it allows mulit valve and effective VVT . with OHC you can change inlet and outlet independantly , something not realistically acheivable with OHV engines. the only benifit I see with using tractor engines is size, yes they are smaller but is physical size worth the trade off? Quote:
[SIGPIC][/SIGPIC]
27-10-2012, 09:37 AM | #112 | |||
27-10-2012, 09:43 AM | #113 | |||
27-10-2012, 09:56 AM | #114 | ||
Street cars in a street environment...the way traffic enforcement is going nowadays, they could have a side valve six banger in them as long as it gave adequate performance and decent efficiency and the vast majority of buyers couldn't care less...
Much less care whether there's pushrods or OHC under the hood...I'd like to know the percentage of people who have ever even asked that question in a dealership...if we be realistic it would probably be down in the single figures... |
27-10-2012, 09:57 AM | #115 | ||
I have to smile at the people here who are talking about ohc and dohc engines being modern developments. Do a litlle research lads and you will find that a man called Otto successfully built ohc ohv engines in the late 1800s. Not a modern development, they have been around for 140 years. Want to read more? Go here- http://library.thinkquest.org/C00601...motor.php3?v=2
Of course, others got into the act, notably Benz and Daimler. Nothing new under the sun? Last edited by graham7773; 27-10-2012 at 10:05 AM. |
27-10-2012, 10:12 AM | #116 | ||||
The engine has everything 'modern' engines do these days, all alloy, direct injection, displacement on demand, vvt, and I'd guess it probably breaths better than most multivalve engines out there. Ironic that someone with the name auXR6 comes on here and ****s on about old tractor engines, the old sohc 4.0 was a real dinosaur for its day compared to the likes of BMW, Mitsi, Mercedes, Nissan etc (suppose it orrite tho as it has the cam in the head?). Quote:
As for multivalve pushrod engines, Cummins B and C series, Ford PSD, Cat C12, C15, DAF X series. |
27-10-2012, 10:48 AM | #117 | |||
Oo\===/oO
But it is a great engine, and just like the LS series before it, it will be the crate motor of choice. And OHC isn't modern...it's still 100 year old tech, its a stupid argument.
27-10-2012, 10:56 AM | #118 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
27-10-2012, 11:06 AM | #119 | ||
Sorry mate.
It makes no sense to remain fixated on the fact the engine does without overhead camshafts, simply for the purpose of criticizing. It doesn't even translate to any shortcomings in power or efficiency. There are clear advantages in weight, packaging, serviceability and cost. There is no substantial claim that this is a bad engine design, it is proven technology that has been refined to remain competitive in various future applications. I've heard many typical one-eyed Holden supporters use this type of ignorant brand snobbery to ridicule blue oval products at their leisure, I didn't expect to hear it from a Ford supporter. |
27-10-2012, 11:21 AM | #120 | |||
N/A all the way
The future is this architecture to allow lower swept volumes, plus turbocharging to allow an engine to act as small or large without the inefficiencies of DOD. Personally, I prefer a 290/302/315 Boss, GM LS, BMW M V10, V8 and straight 6, AMG 6.3 to the new technology with less capacity, turbos or superchargers. But the reality with those engines, is one sticks out as "less modern". But these all have way more soul.
BA GT 5.88 litres of Modular Boss Powered Muscle 300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight |
