Old 18-01-2013, 08:22 AM   #1
Marky89
Default Car stalled after battery re connect
I went to go look at a car yesterday, and the guy said he dis connects the battery because they don't drive it anymore because they bought a new car. Now when we connected the battery back up and started the car, it stalled when idleing. But only once.
I had an racv check done, they said car is in good shape and recommend me to go ahead with purchase.
The racv inspector said it stalled once of initial start up, suspect due to battery disconnect.
Now I've read somewhere that this is common for cars, as the car needs to re learn the idle position and all that when the battery gets reconnected.
Do I have anything to worry about?
The racv inspection didn't find any other mechanical faults.
Marky89 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2013, 09:37 AM   #2
kempy311
BEN
kempy311's Avatar
Default Re: Car stalled after battery re connect
Sounds fine to me like you said some cars need a bit of time to relearn everything . What sort of car is it?
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2013, 10:02 AM   #3
Marky89
It's a vy sv8. I took it for a drive and it drove fine.
Old 18-01-2013, 03:06 PM   #4
The Yeti
The Yeti's Avatar
yep wouldnt loose any sleap over it
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2013, 03:10 PM   #5
ltd
Force Fed Fords
ltd's Avatar
Sounds normal bud.
Go get it and enjoy.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2013, 03:28 PM   #6
The Yeti
The Yeti's Avatar
for the record my wife had a VZ SS and it was a really well balanced car and alot of fun to drive, I think you'll enjoy this
Pariahs C.C.
Old 18-01-2013, 05:00 PM   #7
kempy311
BEN
kempy311's Avatar
Yer our gen 4 landcrusier does it so you have to pump the throttle once you reconnect the battery.
331rwkw.
Old 18-01-2013, 08:09 PM   #8
Marky89
Thanks for the replies guys.
