Old 02-09-2005, 05:52 PM   #1
bscampbell
bscampbell's Avatar
Default What to do when 'storing' cars?
My old XF hasn't seen daylight for about 4 or 5 months now.
If I am to leave it for even longer, what should I do?
I've disconnected the battery, but that's all.
What precautions should I take when I start it up after such a long rest period?
I read about this on the forums before, but can't find it again.
Oct 86 XF Falcon S sedan. Pics
2004 BA Futura wagon Our wagon
2009 VW Caravelle
bscampbell is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 05:56 PM   #2
Kryton
Kryton's Avatar
4-5 months isnt a long rest period at all. ive had cars sit around longer which i did nothing to when i fired it up.
check your fluids and when it starts, let it idle for a while to get everything lubricated again before you go and drive it.
check your tyres too.
Old 02-09-2005, 06:18 PM   #3
Steffo
LPG > You
Steffo's Avatar
Yeah.. our old van sat for over a year with a full tank or 91 RON.. etc. Only thing that happened was the battery went flat.. new battery and it fired up without problems.
LPG Lovers Association President & Member #1.
Steffo is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 06:56 PM   #4
krazzy from nz
Posts: n/a
left my xd 351 ute parked for 15months, new batry and she runs like a dream, let it idle like davway said and should be all good
Old 02-09-2005, 11:19 PM   #5
347Stroker
347Stroker's Avatar
A good tip is to remember where you leave the keys, its bitten me before....lol
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 11:25 PM   #6
pbouzaid
Mondeo MC Titanium Wagon
pbouzaid's Avatar
LOL!! Thats some funny stuff.
pbouzaid is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 11:30 PM   #7
GTP 320
Blueprint Beast
GTP 320's Avatar
I also plan to store my GTP away for about 6 mths,i will have to find a place,maybe i could have it on display at Ford Discovery centre, or are there any other suggestion's ?
Cheers John
FPV & XR Owners Club of Victoria
Leather seats, Premium sound, Sunroof, Satellite Navigation, Reversing sensors, Herrods lowered suspension, Full stainless steel Quad exhaust system, Helix spacer,Open mouth cold air induction,Uni Chip,BMC air filter
GTP 320 is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 11:41 PM   #8
pauljh74
pauljh74's Avatar
I've read what's recommended is to block up the exhaust - perhaps the intake as well so stuff can't get up there. Fill the oil up, fill the petrol tank up, disconnect the battery, put it on axle stands - the tyres could go down. Tyres that stay flat for extended periods tend to go a funny shape where the sidewalls of the flat tyre have been flexed into a position that isn't ideal. Probably not good for the rims either. You may need to drain your fuel and get new juice when you resume using the car.
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 12:32 PM   #9
aimzes
...fairly odd
aimzes's Avatar
yes jack it up. ive heard its a must if the wheels are alloy, but id do just incase you have a slow leak or something in one of the tyres. get some cheapies, your not laying under it! i think i saw them for $40 a pair at supercheap. but since they sponsor murphy id try repco/autobarn/auto1...etc first.
ive been told to drain the radiator. and as said before disconnect battery. im not sure about the tank though.
1992 EB Falcon 5.0 V8. mods; dust, dirt, cobwebs, scratches, trolley dents, dented bonnet, gutter scrapes, rattly exhaust, and floor mats.
aimzes is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 12:41 PM   #10
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
Talking
Cheers John
you could leave it at my place ... ill take real good care of it :
Originally Posted by AL NZ
it wouldn't matter what FPV or FordOz call it, because it will be - The One.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 03:19 PM   #11
tickford2001
ive found that leaving cars for a long time has caused some problems with seals & other materials that tend to go hard and brittle if not used
also, just starting it up every week or so doesnt solve all dramas, you really need to get everything moving, ie. gearbox, diff etc.
apart from that though, shouldnt cause too much trouble
Gone cruising
tickford2001 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 03:26 PM   #12
Kryton
Kryton's Avatar
that is one of the things you do not do to used radiators.
any service manual will tell you that if you remove your radiator and plan to have it out for a period of time it must be submerged under water.
keep the water in it and just put some inhibitor in if need be.
Old 03-09-2005, 08:55 PM   #13
GTP 320
Blueprint Beast
GTP 320's Avatar
You promise that you will lol
Cheers John
