Old 17-05-2010, 05:40 PM   #1
JimNiki
71Mach1
JimNiki's Avatar
Default please pass, running in!
Remember the signs people used to put on their cars.
(I was going to say old classics, but they were everyday cars then)
I remember passing some of them almost every weekend.
XW's, XY's, XA's, XB's
Many of them had a hand written sign on the back window:
PLEASE PASS RUNNING IN
What the hell was all that about!
Have you seen how Ford runs in their engines?
By thrashing them in the factory to bed them in properly.
But I know the real reason for the signs ...
Back then, we all had to prove ourselves on the roads, and if we happen to line up with an old monaro at the lights, well we had a legit excuse!
Sorry ... no go turkey! can't you read the sign!
They were the good ol days...
roses are #FF0000
violets are #0000FF
all my base
are belong to you
JimNiki is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 05:45 PM   #2
SB076
SB076's Avatar
I remember those signs. They used to drive at 60k's everywhere and had to keep the revs below 3000 rpm (or some other figure) It was good fun when you were in a mates car and running late and doing 60'ks on a road you normally drove at twice that speed and your mate refuses to go over 3000 rpm (or 60'ks)
These days I just try to keep varying the revs (by going up and down through the gears)
VIXEN MK II GT 0238
with Sunroof and tinted windows
with out all the go fast bits I actually need :
SB076 is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 06:08 PM   #3
Gaz
Got Ghia?
Gaz's Avatar
Should read
"Cmon try and pass.. Running it in"
Get it warm, then get on it!!
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 06:12 PM   #4
302 XC
arent some motors now bench run to run them in ????
mate many years ago used to rebuild holden red motors
used to idle them for a while double check everything
then a quick blast up the highway
all run in
302 XC is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 06:54 PM   #5
Bossxr8
Peter Car
Bossxr8's Avatar
You couldn't be more wrong. The engines are hot tested in the engine plant first then slowly driven around a tiny test loop when they come off the line in Broadmeadows. They are not thrashed at any point. Maybe you should check your facts before you make claims about something you obviously know nothing about.
Old 17-05-2010, 07:06 PM   #6
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
that test loop is mainly for rattles and squeaks.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 07:41 PM   #7
Bossxr8
Peter Car
Bossxr8's Avatar
Sure is. It would be impossible to thrash a car around it as its probably only 50 metres long and lined by concrete blocks. And its bumpy as hell to stimulate any possible noises.
Old 17-05-2010, 07:54 PM   #8
PepeLePew
Workshop & Performance
PepeLePew's Avatar
Hey if you spent the money back then you were quite inclined to listen to what the manufacturer said to do in the manual.....
2005 LS Focus 2.0 LX daily bye bye 300000km 2004 Kia Cerato 2.0 amazing workhorse
2005 Mazda 6 MPS shiny thing garaged
2008 EO XR5 might finally be for sale shortly I promise myself
PepeLePew is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 08:16 PM   #9
ondori
Addicted User
ondori's Avatar
In the old day's that's what the manual use to say..
good read here..
http://www.mototuneusa.com/break_in_secrets.htm
Pepples before the sand! Then sand all the time
ondori is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 10:14 PM   #10
There is still an argument follow a break in procedure all there is still controversy over the best approach. See http://www.mototuneusa.com/break_in_secrets.htm and
http://www.theaa.com/motoring_advice...a-new-car.html
