04-11-2009, 08:21 PM | #91 | |||
AWD Assassin
Engine heat soak, tyre wear and tear, transmission / clutch temps etc etc......will all play a major part in any serious track attack. As far as the ZF handling abuse........it is well known that these boxes are arguably the best in the world for their smarts and their ability to hang together despite the serious abuse handed to them. Spoolmans ZF equipped F6 has done countless 1/4 mile passes without leaving its guts on the track. I've seen the ZF around a track as driver and spectator enough times to see that it handles circuit duty with aplomb...........in the 6T and V8 anyway. The N/A 6 does not use the same heavy duty version though, so results may be different. |
04-11-2009, 10:13 PM | #92 | ||
If people were programmed to shift gears in a manual the same way the ZF was programmed to shift, the manual would consume a bit less fuel I'd think. Even the auto in the old EL upshifts at stupidly low revs and it can hit 70km/h in 4th gear having not gone over 1500rpm- in a wagon with 3.23 diff. How many people would drive a manual like this? The secret to economy lies in the fact that the engine improves in efficiency the more the throttle is opened. If you can do the same job in a higher gear with slightly more throttle opening, chances are it'll be more fuel efficient than downshifting. Holden specifically said this to motoring journos testing the SIDI cars when climbing up hills- I recall reading that even climbing hills it's more efficient to stay at 1000rpm in top with the throttle pegged than downshifting.
04-11-2009, 10:21 PM | #93 | ||
Measured fuel consumption in city for XR8, 21.4L/100km, regardless of gearbox. In reality this means nothing though because that number is obtained under very controlled conditions.
EDIT: city consumption in XR6 ute is same, 5A or 6M, XR8 city consumption in XR8 ute is LOWER for 6M over auto city consumption in F6 Sedan is same for Auto or Manual city consumption in GT same for Auto or Manual, very close for Hwy Last edited by madmelon; 04-11-2009 at 10:35 PM. |
04-11-2009, 10:34 PM | #94 | |||
Most manuals can drive around at 60km in 5th, most people dont do it though ADR fuel tests doesnt allow for skipped gears, nor does it take into account coasting. Also an Auto will always use more fuel idling in Drive, than a manual idling in Neutral.
04-11-2009, 10:39 PM | #95 | |||
03-07-2010, 11:03 PM | #96 | ||
04-07-2010, 01:51 PM | #97 | ||
04-07-2010, 03:06 PM | #98 | ||
Got Ghia?
That's a nice sound.
I'm finally getting used to it in my 3V... it's a little harder than in the FPV's I think cause the downshift is quite a bit slower due to it being a ghia... :( I push the lever forward and release, then blip the throttle. How's the timing compare on the boss's?
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
04-07-2010, 05:35 PM | #99 | ||
04-07-2010, 05:54 PM | #101 | ||
BOSS 5.4L Enthusiast
If the SCT software for ZF's made the gearbox rev match on downshifts i'd consider one..
That Cobra is Loud, Love it! |
04-07-2010, 05:56 PM | #102 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
04-07-2010, 06:14 PM | #103 | |||
flickr |
04-07-2010, 09:54 PM | #104 | ||
05-07-2010, 10:51 AM | #105 | |||
08-05-2012, 05:37 PM | #106 | |||
UTRIED
BA XR6 03 Townsville Drag 1/10/11 PB: 15.34 @ 91.09 mph |
08-05-2012, 11:24 PM | #107 | |||
A -- Foot on clutch, from 4 to neutral, release clutch, blip the throttle, back on clutch then into 3 release clutch... etc. or B -- From 4 to neutral, blip throttle into 3 ...etc. (be prepared to crunchies until yiou get it right) In both cases bliping the throttle means to get the reves up to what they would be if the box was in 3. Of coursse, that applies to all gears.... 6 to 5 to 4 to 3 etc.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better! |
09-05-2012, 12:04 AM | #108 | |||
Member
09-05-2012, 08:18 AM | #109 | |||
The Villan
New addition! 2010 FG XR50 Turbo in Lightning Strike The PX Ranger has arrived! XLT Metropolitean Grey Previous Ride - 2007 BF MK II XR6 in Lightning Strike
09-05-2012, 08:44 AM | #110 | |||
Throttle blip is really only needed for racing, because the engine braking (shift with zero throttle) can cause the rear wheels to skid/lockup under heavy braking.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
09-05-2012, 10:44 AM | #111 | |||
UTRIED
10-05-2012, 09:20 AM | #112 | ||
Brilliant 0-100 times for both cars. What are the XR6 turbos doing these days? Surely 1 sec quicker? I guess traction is a big one with them.
2023 Mustang Ecoboost HPP Fastback manual Grabber Blue/Magneride/Body colour pack/Forged alloy wheels find me on instagram @adm.history for daily automotive historical Australian advertisements. |
10-05-2012, 09:48 AM | #113 | |||
His: 2015 FG-X XR8 ZF (Stock) & 2009 FG G6ET 370rwkw on pulp 98 and 426rwkw on e85 thanks to Spiro @ Autotech Engineering Hers: 2012 FG MK2 G6ET Previous: 2012 FPV GS Ute 423rwkw |
10-05-2012, 10:02 AM | #114 | |||
...I notice that as per most road tests, they still seem to really concentrate on things that, in the real world, are pretty much irrelevant...things like 0-100, quarter times, and a lap of a track...
One brave magazine many years back (I think it was Motor) started to ignore those things (because let's face it, they're street cars, not race cars, & the general punter could care less about quarter times and 0-100), and began instead testing and publishing 80-110 times (overtaking) and braking distances instead...didn't last long though... Quote:
