#301 | ||
Clevo power!
Hi, this is the wife here. Thanks for giving him some solutions/things to try. He's pretty frustrated. He posted in one of the facebook groups that he's thinking of selling her... I think he'll regret it too much if he does. Roughly how many $$$'s are we talking here? I'm the one who does the budgeting, I'll see if I can scrape up the money somewhere.
I'm hoping once she's running well again he'll get the passion back for the car. I've got the weekend off coming up so if I can get her fixed in time I'll take him for a relaxing drive in her, he hasn't had a chance to enjoy her and take her out for ages, I think that's part of why he wants to sell, all the fun is gone... So how much do I need to find in the budget for her this time? Roughly? And I'll see what I can do to try and stop him selling her. Thanks for all your help and advice. -Sarah |
#302 | |||
![]() Join Date: Jan 2005
The problems are minor IMO and probably just require someone with some experience in those cars to diagnose and fix it. Assuming that the issue is along the lines of what Phil has diagnosed so far then you might be looking at one of the following things. Points, condenser, coil, distributor cap leads. You can probably source all those parts for less than $100 but it's more than likely just one part that has failed. It should be a cheap fix. The proper fix if it's ignition related is to replace the distributor and coil with a new electronic unit. This will set you back around $400 but you can run these things fine with the original units. I have a second hand points distributor for that car in good condition ( if I can find it in my shed) and you can have it if you want it. I also have a coil, cap and leads. Let me know if you want them. The guys on this forum are pretty helpful and if someone is in your location then I expect someone wouldn't mind dropping around to help out. You can place a post in the classic section and ask for assistance. If you don't know how to do that I can post it for you. Unfortunately these cars are getting on a bit and if you drive them a lot then maintenance is an issue. People also forget that when new they needed a lot more TLC then modern cars. He would be mad to sell it and something he would regret. Chris
I love Holdens.... |
#303 | |||
Chris has already touched on the repairs needed For what it's worth what Phil is going through is typical of owning an older car that parts are wearing out / or hasn't been maintained If the budget can afford it I would buy a newer car as a daily drive, living up north one with aircon perhaps Then retire the coupe as the daily drive that way if it needs some work its not something that has to be done right away as its not your primary mode of transport Phil has already scraped the paint work since he has painted it Scrapes and small dings a par for the course when you drive a car every day So in summarising , if you can afford it the coupe should be for fun only (IMO) and if it stops for any reason it can be repaired when the budget allows Get a small fuel efficient reliable daily driver so that Phil doesn't stress about it breaking down or scraping the paint Cheers Tony |
#304 | |||
Clevo power!
Also definitely going to an electronic distributor as soon as I can get one. Just gotta make this old one last till then. Getting my mechanic to look at it this arvo, so he should work it out.
The beast: XB coupe, 302, manual all the way! Fixing up thread The purple monster, daily BA XR6 turbo. Scale Lego Technic XB Coupe with working bits! Build thread |
#305 | |||
When the points open the capacitor forms part of the circuit (it's wired in parallel to the points) and the field collapses and induces a voltage into the secondary winding. It protects the points and provides a timed circuit for the primary winding discharge. The condenser can fail and cause those problems, same with the coil.
#306 | ||
Clevo power!
Wife here again. I've found a good place to take her to, where they specialize in old cars, and as soon as I mentioned the basic issue over the phone he basically said everything you were all saying, which I took as a good sign ;) She's getting picked up by a truck this afternoon, and taken over to SVS (name of auto place) to get properly looked at and hopefully fixed up. I've had a few people say they're really good when I've asked around. Fingers crossed sometime in the next few weeks you'll see some more pics of her out on the road.
As for the daily driver, I've been looking. We're only here in this location though for another nine months, before his work moves us on to Gove in the NT, where we can't take any cars with us. So I have to weigh up if its worth the funds for a car, plus rego etc or just see if the coupe can manage for nine months. Its a tough one. We're gonna have to find a place to store the coupe even while we're up there. We'll probably be there for around a year, possibly a bit more before returning to a place where we can have the coupe with us. If I can find another car cheap enough I'll go for it, but it seems almost a waste of money to buy another car when I'll have to sell it soon anyway. Yet it's also unfair on the coupe to use it like this. - Sarah |
#307 | ||
Sounds like you have found a good place to take it to.
I have the stock Bosch electronic distributor, control box and MSD coil from my Cleveland powered XC that I will not be using. Just before taking it off the car I fitted a new rotor and cap. This type of set-up does not use points so is superior to the older type in the XB. I can send it to you or direct to the garage but the postage from NZ might be quite a lot. I will include the connector for the control box and a wiring diagram. Do you know if the shop is going to fix your existing setup or have you opted to upgrade to a pointless/electronic system? Neill
My dream car/build: http://www.fordforums.com.au/showthread.php?t=11282132 |
#308 | ||
Clevo power!
Wife again, Thanks for the offer of yours, that's Phil's decision to make and I'm sure he'll be on later tonight ;) The shop is going to patch her up for now so we're not running on one car (I can only sometimes take him to work as I work shifts, so some days I can and others I can't). And then I'll get them to give us a proper quote for a pointless system and a few options to go with. Phil wants to upgrade, I don't mind too much, whatever makes him happy haha. If it's going to be better in the long run, then I think its wise to upgrade. They do all kinds of custom work and full restos at the shop I'm taking her to, so I'll get them to have a think what will be best for the car too. Fingers crossed it all goes well. I'm feeling very nervous handing my baby over to someone I don't know! (and yes, it's my baby not his :P Sometimes I'm the one more protective of it than he is!)
- Sarah |
#309 | ||
Clevo power!
Looks like its worse than I first thought. Just heard from new mechanics, who seem to be on the ball...
Looks like the timing chain and or sprockets have slipped or moved. Will make it quite a bit more expensive unfortunately. Oh well will see how it goes.
#310 | ||
That doesn't sound so good. Hope it's sorted quickly.
#311 | ||
Moderator Ford Coupe Club
Tough break Phil. Given your upcoming move to Gove would it be worthwhile mothballing the coupe for a while? Do you have any family or trusted friends who could babysit the coupe for a year or two?? You could then get a cheapie to run around in the short term
Hopefully upon your return from Gove you'll be financially flush and be able to spend some bucks on an engine rebuild or something of that nature. You have two very good things going for you - you're still a young man and you have a very supportive wife. Don't let the coupe go, even if you are having days when you don't like it very much!! You will regret it. Just a thought. One thing I encounter quite a bit at car shows but particularly at our annual Caribbean Gardens show which isn't necessarily a "car" type crowd - lots of guys in my age group come up to us and say they used to have one of these, selling it was the worst thing they'd ever done. Lots of comments like "geez I miss that car". You, Sarah and the XB - the 3 of you were made for each other!!
Mitsubishi ASX Auto, White - Daily Commuter XC Fairmont Coupe, 351 4spd, Graphite Grey - The Antidote http://www.fordcoupeclub.org "If you don't know where you're going, any road will take you there" George Harrison 2001. |
#312 | |||
Clevo power!
#313 | ||
Clevo power!
The timing chain had slipped 4 teeth! That wouldn't have helped at all. Goes much better now apparently. Will pick it up tomorrow arvo which should be good, the bill wont be though...
#314 | ||
Classic cars..... The diet plan for your wallet!
Glad to hear you have got to the bottom of the problems Phil. The cam timing chain moving 4 teeth I must admit is a new one. The usually just break. |
#315 | ||
Clevo power!
Got the coupe back this arvo, goes great!
New Crow double row timing set installed. Now for some pics of the old timing gears and chain: Just a little bit stretched? ![]() Slipped a bit, 3 teeth in the end: ![]() Crankshaft gear a bit worn: ![]() And the stock cam gear, the plastic doesnt look too good after 37 years. Damage to 1 tooth on the left, a bunch on the top right and a few down the bottom: ![]() Here's the worst part of the damage: ![]()
#316 | ||
more cubes please...
That wouldn't have been helping your cause at all. Bit of carbon in that motor too. Does it use much oil? Did you end up getting a good electronic dizzy?
Original T-code XE S-pack. Project thread: http://www.fordforums.com.au/showthread.php?t=11293740 XY Wagon - 351C with 2V AFD alloys, Toploader & 9 inch, GT interior - 13.3 @ 109 XB Hardtop big block project ... I'll get to it one day 1967 FJ40 Landcruiser 'Rusty' |
#317 | |||
Clevo power!
No electronic distributor yet, its running good for now. Ill get to that in a bit.
#318 | ||
Clevo power!
Hey Pat, if your still here can you please get onto me ASAP. I have a problem with the personalised plates.
#319 | ||
Regular Yobbo
Give us a call,Phill,0499637910
![]() ![]() "I BLEED BLUE " QLD number plate....V8 COUPE !!! for sale,make a offer! |
#320 | ||
Clevo power!
Got an electronic distributor today. Should be good once I get it on. Whats involved in installing it? Not something i can do myself? Would need a timing light yeah?
#321 | ||
You will need some wiring mods to get 12v to it. You will need to install it and set the timing up. You will need a timing light.
I assume its a " ready to run " distributor?
#322 | ||
Clevo power!
This is what I have
The beast: XB coupe, 302, manual all the way! Fixing up thread The purple monster, daily BA XR6 turbo. Scale Lego Technic XB Coupe with working bits! Build thread Last edited by Phil B; 18-12-2013 at 12:29 PM. |
#323 | ||
Clevo power!
Well today was the last day of daily duties for the coupe. Will be much nicer on my wallet, driving 110km each day through a mountain pass was expensive in the coupe!
On a good note though, since the timing chain was replaced it's driven very well with no problems at all! The old distributor is pretty stuffed though so I'm thinking it's time to finally put that electronic distributor on. So what will I need to be able to make it work? Do I need a new coil for it? What are the wiring mods? Removing the ballast resistor from the coil power wire? Any other things I'll need? Also I showed a mechanic friend my coupe today (he used to own a few) and he said that he'd never seen a distributor where the gear isn't fixed to the shaft, the gear end slides off with a drive tang. Is this normal? And also he was worried about installing it without the gear falling off, do you just use some grease to hold it on while you install it?
The beast: XB coupe, 302, manual all the way! Fixing up thread The purple monster, daily BA XR6 turbo. Scale Lego Technic XB Coupe with working bits! Build thread Last edited by Phil B; 23-01-2014 at 12:12 AM. |
#324 | ||
Clevo power!
A quick update, coupe is still going great. Got the custom plates on it this week:
![]() Just at work: ![]() ![]() And drove past this coupe at a mechanics shop the other day so I got a picture of both. Its an XA with an XC front, sporting a relatively serious looking Windsor under the bonnet. ![]()
#325 | ||
Always great to see your coupe Phil. Now that she's no longer your daily, how often do you get to drive it?
#326 | ||
Clevo power!
The borrowed daily lasted about a month before the water pump leaked, blowing the radiator. So the coupe is a daily again until that is fixed. Which is only happening slowly because its at my work and I dont get much time to work on it.
#327 | ||
Obsessed with wheels
#328 | ||
Clevo power!
Looks like it could be, a few changes I can see but nothing to drastic.
#329 | ||
This coupe was last photoed in Cairns in 2011, I was looking through the coupe spotting thread. Where abouts are you Phil? I notice you've got Qld number plates now not Vic ones.
#330 | ||
Clevo power!
I'm in Cairns as well now so that will most likely be the same coupe.
