Old 29-05-2014, 09:58 AM   #1
Wretched
Render unto Caesar
Wretched's Avatar
Default Audi RS5 TDI - Concept
Originally Posted by Autocar
Audi RS5 V6 TDI-e prototype first drive review
Ingolstadt's new electric turbo technology produces stunning performance, potentially paving the way for a sporty diesel RS production model
What is it?
A late-stage prototype Audi RS5, fitted with a very potent ‘e-boost’ version of the next-generation Audi 3.0-litre V6 two-stage turbodiesel engine.
The new engine weighs 192kg, somewhat lighter than the previous version, and will arrive first this summer in the newly facelifted A6 and A7 in 215bhp and 268bhp forms. This 380bhp prototype, however, is expected to go into production next year, possibly as the first-everAudi RS diesel.
Like many of today’s higher-end diesel engines, the new unit uses two-stage turbocharging. The smaller of the two is lighter and easier to spin up, and is intended to give the engine more grunt at lower engine speeds. The bigger turbo takes over at higher speeds.
The engine we’ve driven here is, however, something of a landmark design in that it uses electrical assistance to ensure that the smaller of the two turbochargers is spinning quickly enough to be active even at very low engine speeds.
In simple terms, Audi engineers have added an electrically powered blower to the engine’s induction system, which, at very low engine speeds, forces air into the induction system, spinning the smaller turbo into life.
This ‘e-booster’ is connected to the engine’s intercooler on one side and to the induction system on the other, pushing air through the smaller turbocharger impeller between start-up and 3000rpm. At higher speeds, the e-booster is bypassed entirely.
The e-booster is also intended to keep the engine on boil on, say, twisty back roads. Typically with diesel engines, braking for a corner also slows the engine and bleeds off boost. This results in slower acceleration out of the same corner while the engine spins up enough to get the turbos back on boost.
But fitted with this new e-booster, the engine’s turbochargers can be primed while the driver is still braking, so that full torque is available virtually immediately the driver gets back on the gas.
Although Audi engineers experimented with turbocharger units that were driven directly by an electric motor, they decided not to pursue the design because it resulted in extra inertia, which, ironically, slowed the turbocharger response times.
The e-booster is powered by its own 48v electrical system, while the rest of the car uses a conventional 12v electrical system.
What is it like?
As you might expect with 553lb ft of torque on tap from just 1250rpm, this Audi RS5 diesel is bombastically rapid.
We drove the car at Audi’s new short driver training circuit near Munich. While this was a long way from the open road, the track’s very tight curves, which demand a great deal of braking and re-acceleration, were ideal for testing out the ‘e-boost’ promise.
We followed a hot RS6 pace car – driven by a professional Audi driver – around the track in order to give us some idea of how this RS5 prototype can deal with Audi’s fastest RS road car.
From a standing start, the RS5 had the measure of the RS6 for the first couple of seconds, before the RS6 pulled away. There’s no doubt that that this engine gets away from rest very quickly indeed. But after that the wall of seamless torque never seems to let up.
Left in the automatic gearbox's ‘Sports’ mode, the engine never had a chance of revving out, not just because the transmission’s brain wouldn’t let it – there’s little point in trying with torque peaking at 2000rpm and power at 4200rpm.
Another part of the reason that the engine responds less like a diesel is that the crankshaft, conrods and pistons have all been redesigned to reduce weight. These reciprocating parts are a claimed 20kg lighter than normal. That’s a lot less mass to speed up and slow down.
The promise of massive pull being instantly on tap as you pull out of slow corners is absolutely upheld. On six quick-ish laps, the engine was never left floundering for instant pace. Indeed, this engine drives hard enough to have the torque-vectoring rear differential working right up to the point it has to let the rear wheels slide a little.
Though I’m sure purists will say the car’s dynamic performance is ‘artificial’, this Audi RS5 doesn’t understeer. The steering weight remains constant even under the hardest cornering and – importantly – it is relatively easy to drive very hard.
Should I buy one?
You can’t – yet. While the Audi engineers on hand during our test were tight-lipped, I’d expect this engine to be offered some time next year.
It is also likely to appear in RS form thanks to the fact that the ‘diesel-ness’ of this unit has been almost entirely eliminated, thanks to a combination of e-boosting, its pretty free-revving nature and the artificial sound generation of the exhaust system.
The question that hasn’t yet been answered is why RS customers – who presumably are not too sensitive to petrol prices – would want to buy a diesel-powered car. The Audi engineers I spoke to are still very bullish on the future of diesel and suggest that oil-burning is still the supreme motive power for long distance, high-speed, motorway journeys and cross-continental drives.
Moreover, after winning Le Mans with diesel powered sports cars, Audi finally has a diesel engine good enough to put in a future R8.
I like the sound of this concept.
All the benefits of efficiency with no loss of performance.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson
Wretched is online now   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 08:11 PM   #2
Bossxr8
Peter Car
Bossxr8's Avatar
Default Re: Audi RS5 TDI - Concept
What would you rather, the screaming 4.2 at 8000 rpm, or a rattly tractor engine at 4200 rpm.
Sounds like a good engine though, but not in an RS, maybe just keep it to the S models IMO.
Old 29-05-2014, 08:31 PM   #3
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Rattly tractor engine for the win, I love diesel engines. Diesel V8, best of both worlds lol.
Remember theres more energy in diesel than there is in ol' mate unleaded.
There isn't much about diesel performance here in Australia as there is in the USA and Europe, USA takes it to the next level with some of their stuff, with a Cummins 6BT all you need is one with the Bosch P7100 injection pump, turn up the fuel and change injectors and you're already at around 300hp.
Two of the forum members here have F series with a Cummins 6BT conversion in them.
People with the UK Mondeo with the 2.2L diesel engine are putting out around the same power as what the XR5 is with minor mods and tuning but with lots more torque.
Diesel has potential but it just has to be realised, as they're not popular here in Australia unfortunately we're limited with knowledge.
Old 29-05-2014, 08:34 PM   #4
Wretched
Render unto Caesar
Wretched's Avatar
Rattly tractor engine?
If it this is the rattly tractor engine then I'll take two.
http://youtu.be/DU9bWl5vVFc
If I am spending that kind of money I want more than just sound.
If I just wanted sound I could get any old Holden or Ford V8.
Old 31-05-2014, 04:51 PM   #5
KAM120
KAM120's Avatar
Should be a good engine, but until they can get them to spin up to 6000 or more ill be sticking to the petrol screamer thanks.
KAM120 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2014, 07:57 AM   #6
Wretched
Render unto Caesar
Wretched's Avatar
http://youtu.be/MMfP6YP2Y9Q
Old 16-06-2014, 08:17 AM   #7
Polyal
The 'Stihl' Man
Polyal's Avatar
Damn the A5 shape is nice. Is it 2 + 2?
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
