Old 29-12-2014, 01:20 PM   #1
Poorboy_racer
Poorboy_racer's Avatar
Default Car looses 2.5 seconds?
Crewing for a mates Supercharged BA at the Perth Motorplex yesterday. Cars been running high 11s no problem. Not changed anything but for some reason the car wouldn't run any better than a 13.5 yesterday. As min dial in is a 12.99 we were out 1st run. The air was really bad. But 3 seconds, no way. Now heres the rub. The meeting was abandoned as there was a power pole fire and there were no lights at the Plex. Is been rescheduled for the 2nd but nowhere is open. Just wondering if anyone had any ideas what we could do. Have not re flashed the car as the owner (not me) has no idea if the tuner has the latest tune in it or not. I suppose at this point we have nothing to loose by trying.
Poorboy_racer is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2014, 01:43 PM   #2
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Default Re: Car looses 2.5 seconds?
Did the MPH drop too?
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2014, 03:41 PM   #3
Poorboy_racer
yes it just didn't want to rev
Old 29-12-2014, 04:07 PM   #4
APS Luis
cat convertors blocked
A.P.S. Service Centre
A.P.S. Performance Tuning
www.apsperformancetuning.com.au
www.apsservicecentre.com.au
APS Luis is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2014, 06:35 PM   #5
Poorboy_racer
The car is a race car. It has dump pipes that stop under the drivers seat. So no catalytic converter.
Thanks for the suggestion anyway.
Old 29-12-2014, 06:42 PM   #6
Poorboy_racer
http://i69.photobucket.com/albums/i8...ps0823edc8.jpg
Old 29-12-2014, 08:19 PM   #7
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
what charger and what is it tuned with?
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2014, 10:44 PM   #8
Poorboy_racer
Is a vortech S/D 13 lb of boost running on that E85 fuel. its only just been retuned to run on the E85 before the last time out. So we don't know if the flash tune is for E85 or 98 Octane. So until BPT re open we are a bit relucent to do a flash tune
Old 29-12-2014, 11:06 PM   #9
ratter
ratter's Avatar
which flash box do you have, Xcal 3 can tell you what the last loaded tune was. If you were running E85 in the tank but had 98 octane map loaded, the car would be very lean, have you looked at the fuel trims?
Is the belt slipping?
Old 29-12-2014, 11:54 PM   #10
Poorboy_racer
Quite sure the charger belts not slipping. The flash tuner is a CAPA ford Flash two.
Fuel trims?
Old 30-12-2014, 06:07 PM   #11
Poorboy_racer
Watched this : https://www.youtube.com/watch?v=5WnM_NsOtd8
and part 2 .
Very interesting explanation of fuel trims.
Any thoughts on how the O2 sensor will react for forced induction?
We have been informed that the re-scheduled meeting will continue from where the abandoned meeting left off. So we are knocked out anyway. No panic now, we can wait for BPT to reopen before our next meeting on the 9th Jan so we should have time to get it fixed. Appreciate the comments and suggestions anyway and learnt a bit about fuel trims.
Old 30-12-2014, 09:52 PM   #12
ratter
ratter's Avatar
o2 sensor should not be affected by forced induction at all, the SC 5.0 and turbo 6's have no issues
Old 31-12-2014, 04:41 PM   #13
Poorboy_racer
Was thinking that as the O2 sensor monitors the exhaust gasses coming out of the engine after combustion, forced induction should make no difference if they monitored the air going in before combustion then that would be different story. The MAF sensor has been changed.
Old 01-01-2015, 08:51 AM   #14
ratter
ratter's Avatar
A BA does not have a MAF sensor
Old 01-01-2015, 11:56 AM   #15
bluewindsor
Could it have been a bad batch of fuel?
bluewindsor is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2015, 01:24 PM   #16
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Map sensor
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2015, 06:46 PM   #17
Poorboy_racer
Cars gone back to BPT now. They are saying drastic drop in boost but we don't know why at the moment. They are looking into it.
Map.....Maf......typo, As said earlier its not my car. I didn't get, or do any of the work done on it. I just check the fuel level, tyre pressures, dial ins etc. Therefore I can only relay information given to me by the owner.
Old 07-01-2015, 07:54 PM   #18
Poorboy_racer
Turns out there was a large crack in the pipe between the supercharger and throttle body. New pipework fitted its all good now. Thanks for the suggestions.
