Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > ASL automedia
ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link
Old 28-08-2012, 08:57 PM   #1
FTE-063
FTE-063's Avatar
Default bf icc security code urgent help!!!
today i pulled out the icc to fit a overlay touchscreen, refitted the icc, security code came on the screen,
with the ignition off i pressed the volume button nothing
turned the car on [starts ok] still no response from all the buttons on the entire icc, the icc screen lights up though.
FTE-063 is online now   Reply With Quote Multi-Quote with this Post
Old 28-08-2012, 09:21 PM   #2
XARATE
XARATE's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Quality contribution which has gone somewhat un-noticed so far.
Default Re: bf icc security code urgent help!!!
Have you pressed the volume button with the ignition on?
270rwkw BA XR8
http://www.fordforums.com.au/showthread.php?t=11339147
XARATE is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2012, 09:24 PM   #3
FTE-063
FTE-063's Avatar
hey done that still nothing
Old 28-08-2012, 09:32 PM   #4
Cashie
Cashie's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Multiple helpful contributions throughout the tech area.
There's no code, are you sure it's back together correctly and it's seated back in the plug and socket at the rear correctly?
Pull it out again and make sure the socket attached to the car is pulled all the way out before reseating the ICC.
Current Rides:
2017 Ford Mustang
2020 Ford Everest Sport
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2008 BF XR6 Turbo Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Cashie is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2012, 09:41 PM   #5
FTE-063
FTE-063's Avatar
the big white plug at the back, how do you pull it foward to hear a click, i've tried pulling it outward nothng is there a special way to pull it foward??
does it matter which plug i pull out first [the 5x plugs under the icc??
Old 28-08-2012, 09:45 PM   #6
XARATE
XARATE's Avatar
Yes it matter which ones- if the battery is still connected. If the wring plug is pulled first with the battery connected you can damage that
270rwkw BA XR8
Old 28-08-2012, 09:49 PM   #7
FTE-063
FTE-063's Avatar
damage what?? and yes the battery was still connected when i pulled the plugs out
Old 28-08-2012, 09:53 PM   #8
Cashie
Cashie's Avatar
From memory the plugs are removed right to left and connected in the reverse.
And as mentioned, the order is important.
Did you hear lots of relay clicking when you were unplugging the plugs?
Current Rides:
2017 Ford Mustang
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Old 28-08-2012, 09:58 PM   #9
FTE-063
FTE-063's Avatar
i'll have another go tomorrow if all else fails, i'll just take it to asl to get them to have a look??
Old 28-08-2012, 10:05 PM   #10
Cashie
Cashie's Avatar
Might be a good idea, and no problems for the advice.
Current Rides:
2017 Ford Mustang
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Old 28-08-2012, 10:05 PM   #11
FTE-063
FTE-063's Avatar
__________________only when i connected the second one from left [black] first then soon as i connected the first from left [white] the clicking stop..
have i damaged the icc?? or a relay
Old 28-08-2012, 10:08 PM   #12
Cashie
Cashie's Avatar
http://www.fordforums.com.au/vbporta...article&id=182
And I ask again, did you put the ICC back together correctly?
Current Rides:
2017 Ford Mustang
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Old 28-08-2012, 10:14 PM   #13
FTE-063
FTE-063's Avatar
thanks cashie i've read that post early before
Old 28-08-2012, 10:17 PM   #14
Cashie
Cashie's Avatar
Ok, doesn't that post cover the plug order and the white socket pulling out?
I thought it covered it all pretty well?
Current Rides:
2017 Ford Mustang
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Old 28-08-2012, 10:49 PM   #15
FTE-063
FTE-063's Avatar
yes it does but for the life of me i can't to seam to pull the white connector foward to hear a audible click
Old 28-08-2012, 11:41 PM   #16
auMatt
ORSM Ford Cruisers
auMatt's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Matt's valued contributions in the technical area associated with AU/BA/BF & Terri instrument clusters & ICC's is considered the authoritative guide to work by members in this are of expertise. His contributions stand alone in the forum in this technical
Video shows how the plug should go in.
2004 Harvest Green XR6
Orsm Ford Cruisers
ORSM Ford Cruiser's Web Site
Contact me for all your Cluster Programming/Repairs & Window switch/ICC colour change for BA/BF/FG Falcons & Territory. Visit my SITE for info.
I Use and Recommend :
Ferntree Gully Auto Salvage
AutoWorks - Keilor
RIP Craig
RIP Samantha
auMatt is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2012, 07:45 AM   #17
FTE-063
FTE-063's Avatar
you are a legend aumatt, that video makes more sense now
Old 29-08-2012, 08:05 AM   #18
FTE-063
FTE-063's Avatar
i had a second look at the video it seams that the white plug in my car is fully out so what could it be?? would i cause something when i unpluged the 5x plugs in different sequence
Old 29-08-2012, 09:21 AM   #19
FADI75
Sponsor
HI
check if you havent damaged any of the pins on the connectors while sliding ICC in and out, sometimes due to removal and refit pins get bent or broken
cheers
fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS
AUTHORISED FORD REPAIR CENTRE
website: www.aslautomedia.com.au
email: info@aslautomedia.com
AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2012, 09:30 AM   #20
FTE-063
FTE-063's Avatar
hey fadi, i'll have a look this morning if not, can i bring it today for you guys to a look?? cheers dean
Old 29-08-2012, 10:04 AM   #21
FADI75
Sponsor
Dean
we can have a look tomorrow no problem
cheers
fadi75
Old 29-08-2012, 10:14 AM   #22
FTE-063
FTE-063's Avatar
thanks fadi, but my car is booked in to herrods for next 2 days
i'll give you a call next week if i can have a half a day off from work.
Old 16-07-2014, 03:56 PM   #23
GSK33
Great video. I own a 2006 bf Futura and the main white plug and black surround need replacing. Can this be done?
GSK33 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2014, 10:39 AM   #24
Auxr6t
I also need to if this plug can be replaced. I have broken the clips on the black part and cannot get it to plug in because it pushes the plug back into the dash
Please help
Auxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2016, 12:58 PM   #25
sexyr6
hmmmm boost
sexyr6's Avatar
Searching for an answer to this problem there is not much that is mentioned on what resolves the issue, today I did a job where i needed to replace a faulty ICC, and once i fitted the new unit i got the "CODE" come up on the screen, long story short, the bottom right bolt that holds the ICC unit to the car is an earth point, and once i screwed the bolt in the "CODE" went away, just thought this info would be useful for someone in the future.
Daily Driver - EB Fairmont Wagon, 347, Cardinal Red.
The Toy - 94 ED XR6 5spd, Pearl Black, 253rwkw of boosted goodness.
sexyr6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2016, 11:37 AM   #26
Bearr
Typhute Designer & Owner
Bearr's Avatar
THANK YOU SEXYR6, My problem answered!!! Legend.
Now to go and try.
Bj
Bearr is offline   Reply With Quote Multi-Quote with this Post
