Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Falcon GT club of SA > General Discussion
Old 05-08-2016, 08:27 AM   #1
Paul Spencer
Default Xb with missing i.d. Plate
Hi. I've just joined and this is my first post. I have recently purchased a matching numbers 1976 Ford XB 302 V8 ute which I am currently restoring. The vehicle does not have either compliance or Body I.D. plates. How can I find out what model and options it had - ie information that would have been stamped on the plate? The engine/chassis number is JG40SA81416K. Thanks for any help. Paul.
Paul Spencer is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2016, 04:43 PM   #2
Paull
P6 LTD
Paull's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all the hard work performed around paint, trim, engine codes in the Classics section. General all round knwoledge and willingness to impart on others
Default Re: Xb with missing i.d. Plate
Have a look here
http://www.fordforums.com.au/showthread.php?t=11225420
At any rate;
JG - Aus build in Broadmeadows
40 - Utility
S - 1976
A - March
Phone: 13-FORD or email customers@fordcrc.com.au
When contacting CRC, they can tell you what options your car came out with. What you should be able to tell straight up is options such as GS Pack, twin exhaust etc.
Have you contacted the local coppers to ensure that the car is not stolen as well as you will be able to license the car, without VIN plates?
Paull is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2016, 05:26 PM   #3
XB GS 351 Coupe
I would be wondering what happened to the plates.
I would also be making enquiries with the police and motor registry in relation to the vehicle, it's ID and history, no point spending money on it if it turns out to be stolen, or can not be registered for what ever reason.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2016, 07:32 PM   #4
Paul Spencer
Thanks for your advice. Before I purchased the ute I noticed that there was a Victorian number plate in the back tray and rang VicRoads in order to find out whether there will be any problems registering it when it's restored. They confirmed that the plate did match the description of the vehicle and advised that the last time it was registered was in 2001. Apparently, as long as they can verify that the vehicle has been registered in the past, there shouldn't be an issue with getting registration without I.D. plates. I will check with the Police as well as you suggested.
