Old 06-11-2017, 10:50 AM   #1
LEEG
Default g6e radiator fan problem
When I turn on air con the radiator fans come on both full speed sounds like F1 11 aircraft . turn air con off fans run fine, codes say solar sensors out of range location and remedy. any help please GEOFF
LEEG is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2017, 03:47 PM   #2
GTLEGEND
Default Re: g6e radiator fan problem
If you had an AC service lately, too much gas in the system will cause the fans to run at high speed all the time.
Just a possible cause..
Old 07-11-2017, 04:42 PM   #3
LEEG
Thanks for your suggestion but air con has not been touched ,this problem just started out of the blue regards Geoff
