Would anyone know what fords came out with a 302 windsor and c4
Sent from my iPhone using Tapatalk |
Thanks guys doing up a xm and looking for a donor car for running gear
Mustang GT mmmmmm......
Donor car with a V8 and C4 will be hard to find.
Might get a motor and trans from a Mustang where someone is doing an engine conversion.
I have become a Mustanger. |
Might be worth sourcing them separately. Go for a EB-AU fuel injected Windsor which will likely have much less bore wear and swap the intake over for an aftermarket intake/carb.
![]() Join Date: Dec 2004
You can as suggested use a late model Windsor . There are a few variations of C4 bellhousing and case combinations . Most can be made to work on that motor with the right combination of bellhousing and flexplate / converter.
Happy to help you on the gearbox side if you need advice |
Hangar pilot....
Be careful if using a later model block and removing EFI gear.
Engineering regs might still require the use of the anti pollution stuff inc. cat converters due to the engine number and date of the block.
_______________________________ AUIII Herrod XR8 ute- Occasional duties 1966 XR Fairmont- Weekend cruiser 1970 XW wagon- Rusty project |
