Old 21-12-2017, 10:51 AM   #1
Pepscobra
Call me dirt... Joe Dirt
Pepscobra's Avatar
Default Jumper Leads / Booster Cables
I got caught with a flat battery recently.
There were plenty of people willing to assist, but no one had leads. Had to wait an hour for roadside assistance.
So now have decided to buy a set and keep in my car.
What Amp size is a good general purpose set?
Cheers.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100
Mods so far:
Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines
Mods to come:
4.11 Diff Gears|Chromoly Tailshaft
I use & recommend:
Castrol|Motorcraft|Mainlube|Penrite
Check Out My Build Thread
Pepscobra is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 10:55 AM   #2
Default Re: Jumper Leads / Booster Cables
Cheers.
400 to 600 amp ones should be enough.
Old 21-12-2017, 11:02 AM   #3
You could also consider getting yourself a mini Lithium powered Jumper Starter that fits in the glove box like the one I have, for not much more dollars;
Smart Jump Starter - Fits in Glovebox - Never be left stranded
Old 21-12-2017, 11:57 AM   #4
http://www.supercheapauto.com.au/Pro...-Amp-3m/365709
Old 21-12-2017, 12:20 PM   #5
Interceptor
HSV - I just ate one!
Interceptor's Avatar
get the heaviest set you can find/afford
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 12:25 PM   #6
You Yangs
Dunnydore Destroyer
You Yangs's Avatar
Thumbs up Re: Jumper Leads / Booster Cables
http://www.supercheapauto.com.au/Pro...Monitor/540712
Get one of these!!
I have one and it's brilliant, it will tell you your battery is kaput way before you'll ever need jumper leads.
______________________________________
"SKIN ON SKIN, LET THE LOVE BEGIN"
You Yangs is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 12:52 PM   #7
Get one of these!!
Looks good... Here's the demo video on that monitor;
Old 21-12-2017, 12:59 PM   #8
Itsme
Itsme's Avatar
Get one of these!!
Ok if you are old school and check your oil & coolant daily but most people these days would not know how to lift a bonnet let alone check anything under it.
Old 21-12-2017, 01:33 PM   #9
Once car makers started putting stupid plastic covers on their engines and hiding everything, so owners lifted the bonnet and thought; "I can't see anything...arh.. Too complicated, I'll leave it to the prosfessionals!" ... Spelt the end of the DIY car fixing / servicing era.
That's why I like the FG - FG X i6 engine bays.... No silly engine covers, a modern car but still looks "old school" and simple to work on and get to everything.
Old 21-12-2017, 02:21 PM   #10
So that's why they all do that....
marty351 is online now   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 02:37 PM   #11
There's more money for a dealer in servicing / repairing a new car over 5 years than when the dealer first sells it to you.
Old 21-12-2017, 02:48 PM   #12
yearby
Twice I have tried to start peoples vehicles with their own jumper leads and the engine would not even crank, so then had to get out my own heavy jumper leads and the vehicle started. One guy had just walked 2 miles and purchased a set to start his vehicle and they where total rubbish. SO DON"T BUY THAT CHINISE RUBBISH.
yearby is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 02:58 PM   #13
I prefer to carry the mini Jump starter to start someone else's car, rather than using jumper cables.... Because there is always the possibility of damaging your own car's electrical and electronic systems being a good Samaritan hooking both cars together.
Old 21-12-2017, 03:52 PM   #14
Itsme
Itsme's Avatar
Regardless of what type of jumper leads used I usually connect the two batteries and wait about 10 minutes before I attempt to start the vehicle as this ensures the flat battery to get a bit of charge in it then start up with no issues.
Works every time.
Cheers.
Old 21-12-2017, 04:36 PM   #15
roKWiz
Cabover nut
roKWiz's Avatar
Having trucks, I keep a couple of sets of long, heavy jumper leads one at home and one with whatever truck I'm using at the time. You can not go wrong with oversized leads.
Several times I've jump started cars with useless undersized cheap sets which tend to fry.
A volt / amp meter is useful as well but I spose they're a rare thing in cars these days.
Old 21-12-2017, 04:37 PM   #16
You Yangs
Dunnydore Destroyer
You Yangs's Avatar
It has an App, the tech hungry Millennials should lap this sort of gadget up shouldn't they?
Old 21-12-2017, 04:58 PM   #17
Electrolyte Burns
You are much better off just making your own. Buy some heavy 35 or 50mm battery cable, 4 lugs to suit and a set of heavy alligator clips.
Won't be cheap mind but will last a lifetime.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 05:05 PM   #18
Tassie f100
I second that.You can get 70mm cable for maybe $10-12 per metre.6 metres of cable and $30 for some heavy duty clamps and away you go,for not much more than 100 bucks,and they will start anything and last forever.
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 05:28 PM   #19
Tonz
Where does one get these from? please....
Tonz is online now   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 06:35 PM   #20
Different brands but do the same thing... They are available at Supercheap, Autobarn and other Auto stores.
Alternatively, if you want the one I have, here is their website where you can contact them for their resellers in your area;
http://smartjumpstarters.com.au
Old 21-12-2017, 10:34 PM   #21
jaydee
jaydee's Avatar
Cheers.
Just as well it wasn't in some paddock out the back of whoop whoop ratting parts of an old car, we'd still be there. .
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2017, 11:51 PM   #22
commodorenutt
commodorenutt's Avatar
+1 for the lithium jumper pack. They are unbelievable for the size.
I bought an eBay one for something like $125 from a seller I'd bought a fair bit off before (who has a bricks & mortar business in a regional town) so I figured it would be a decent product). It's been great.
I've used it to jump carby V8 Commodores that have been parked for a while, and more recently, a diesel Colorado when it's battery crapped itself overnight when we were on a trip. The stuffed battery couldn't even get the starter solenoid to click. Left the jumper pack connected for about a minute (the little leads got real hot) and it gave enough to slowly crank it over & start up the diesel.
I keep it in the boot of the FG. The one I have came with a 240V charger, 12V charger, and an "octopus" of leads to charge a myriad of i-devices. It's all in a neat zipper bag. I've jumped 3 different cars at work - 2 were from leaving lights on (not all modern cars cut them or give warnings), and the 3rd was a stuffed battery - got them going enough to get to supercheap to get a new battery bought & fitted.
Don't believe the amp-hour ratings on them. Some claim things like 40,000mAh, but there's 5 8000mAh cells connected in series..... And don't let what you may consider a low capacity put you off - those lithium cells can dump their voltage in a short time - giving the dead battery enough juice to kick over. You won't start a car with one if there's no battery in it - they are used to "top up" the car's battery enough to get it started again.
commodorenutt is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2017, 08:05 PM   #23
747jet
2 4 turning 2 4 burning
747jet's Avatar
Have you considered in buying a new battery!!! People Ike you keep me in a job thanks mate
im still driving like im 18
747jet is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2017, 08:34 PM   #24
commodorenutt
Forgot to mention too - having a jumper pack means you don't need to find a willing volunteer to get a jump start from either.
It's harder & harder to find a volunteer as many people fear frying the ECU and other nasty things they've heard stories about. It's extremely rare that it can happen, and usually caused by incorrect polarity, or not knowing where to place the leads - or letting it run with no battery connected, so the alt voltage spirals out of control.
Old 22-12-2017, 08:46 PM   #25
Good points!
It's probably worth mentioning here the correct procedure for using jumper cables.
Surprisingly, most people who think they know how to jump-start another car, get it wrong in STEP 4;
