Old 28-12-2017, 10:07 PM   #1
BLSTIC
Default Does anyone in Australia do injector matching?
Does anyone do injector matching? Not static flow tests, dynamic ones at various pulsewidths and duty cycles, like Injector Dynamics do for their new injectors. It's not technically demanding, just time consuming.
Not ordering ID because I don't need the extra flow, just the extra consistency
Chuck Norris beat Tetris
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2017, 08:55 AM   #2
baboon
Contributor: For members who make a contribution worthy of recognition. - Issue reason: went to the trouble of posting up some great Vids of the AFF drag meet
Default Re: Does anyone in Australia do injector matching?
May not be what you want, but it wont hurt to ask them whats involved with their "Flow Rate Test * You receive a complete Test Report with both Pre and Post Cleaning results."
See efi hardware in Mitcham Victoria. INJECTOR CLEANING & TESTING
You could probably ask them if they could do a dynamic test at different injector pulse widths, and they may do it for a fee?
Good luck.
baboon is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2017, 09:11 AM   #3
BLSTIC
No, the only way to do dynamic matching is to dynamically test perhaps 50-60 of the same injector, and you *might* get two sets. It's a time consuming process and any injector shop that does it will be shouting it from the rooftops.
I think I might have to build a testing rig and go down to the local ford wrecker and do a deal and pull *all* their barra injectors.
Would anyone buy sets of stock but matched injectors?
Old 29-12-2017, 09:22 AM   #4
baboon
Whats your budget to do these tests? Under $1000?
Old 29-12-2017, 09:32 AM   #5
BLSTIC
If I'm doing the tests myself, I would expect to be able to build makeshift tooling for a bit under that. After that it's just time and cleaning fluid, and I don't know how much of either I would need
Paying someone who already does it? No idea, again I don't know how much time it takes so I can't set a fair budget. But I would find it fair to pay around the brand new price ($3-400 apparently) for a set of 2ndhand but matched injectors
Old 29-12-2017, 09:43 AM   #6
baboon
I remember going to a fuel information night held by KPM Motorsport and they do build injectors that are matched "As always KPM precisely test every injector to offer matched sets within +/- 1% of each other. We also generate the correct data for your tuning software so that takes any guess work out. "
For example KPM 1700cc Injectors
But from their website they can sell a set of 6 for $649 for BA/BF n/a or turbo saying: " The injectors are a complete, machined, flow tested set. Along with the injectors we provide the scaling data used for precise tuning."
You could contact them and they may offer a service to match a set of stock injectors and provide data you need.
Good luck.
Old 29-12-2017, 10:19 AM   #7
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
As already mentioned, matching a set may require an initial 20 or 50 or more injectors to get a set of 6 perfectly matched injectors.
Most engines would have a bigger variance between cylinders than a set of stock injectors would be.
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2017, 10:22 AM   #8
BLSTIC
But not when I'm finished with my head and manifold... (I will be heavily modifying a stock bbm to remove the long runners for increased plenum volume, assuming that's actually possible)
In any case I should be able to (roughly) predict which cylinders will run differently and strategically position un-matched but tested injectors to suit
Old 29-12-2017, 11:01 AM   #9
ratter
ratter's Avatar
You could run individual wideband o2 sensors in each exhaust manifold runner to monitor each cylinder and locate injectors based on the data
Old 29-12-2017, 12:08 PM   #10
BLSTIC
Unfortunately that's somewhat out of my budget
Old 29-12-2017, 04:16 PM   #11
ozrunner
Why not go to the US.
I've brought 3 sets of basic injectors from these guys and all were awesome.
They do custom injectors which are specifically tested as per your request.
https://www.fiveomotorsport.com/custom-fuel-injectors/
ozrunner is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2017, 11:18 PM   #12
ebxr8240
Performance moderator
ebxr8240's Avatar
Yep me too ..
Daily driver GTE FG..
