Old 18-06-2018, 11:41 AM   #1
pezcat19
pezcat19's Avatar
Default FG Auto-Dim mirror question - button or no button???
Hi all,
Just a quick question: I'm going to add a Auto-Dim mirror for my 2011 MK1 FG F6, but I see that Ford seem to have put 2 different versions in the FG's...
One has a power button on the front, and one doesn't.
Can anyone tell me what is the best version to go for? And, what does the button actually do?
Thanks in advance!
Pez
2011 FPV F6 Auto
pezcat19 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2018, 11:46 AM   #2
Olbucko
Olbucko's Avatar
Default Re: FG Auto-Dim mirror question - button or no button???
Originally Posted by pezcat19 View Post
Hi all,
Thanks in advance!
Pez
I had one with a button in an SY Territory Ghia, all it did was turn the auto dimming function off.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
Olbucko is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2018, 11:53 AM   #3
Vesper Martini
Vesper Martini's Avatar
if you have one of theses. there would be no reason to switch it off. they are fantastic. so id say you wouldnt need the button.
Though the ones I've had on my Ghia & Titanium both have switches. so id be querying the one with no button was actually an auto-dim.
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2018, 12:17 PM   #4
pezcat19
pezcat19's Avatar
Yep - makes sense.
I guess the advantage of a button could be (for my situation), that if I was lazy and couldn't be bothered hooking up the "reverse" sense / input wire, that all I would need is switched power and GND. Thats simple....
Then when reversing at night, if I wanted the mirror to turn OFF (not dim), I could just hit the button, instead of it happening automatically when the reverse lights come on...
Cool.
2011 FPV F6 Auto
Old 18-06-2018, 08:56 PM   #5
marcyeo
Regular member
marcyeo's Avatar
I have a 2014 FG MK2 GT - and it has the auto dimming mirror without a button.
It's always worked, and seems to be mostly noticeable at night when headlights are shone directly in the mirror, so I've never needed to turn it off. On occasion it is also noticeable when I'm in my dark garage reversing out into the sunlight - but that also helps, so I reckon you don't need a button because you won't need to turn it off.
CURRENT
2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance.
OLD
2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw
marcyeo is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2018, 09:02 PM   #6
pezcat19
pezcat19's Avatar
Yep you are right, however yours will (should) turn off when you select reverse automatically. Unless I go to the the trouble to running a reverse wire up to the mirror mine wont turn off in reverse, so in the unlikely event that this causes me a problem, the button will override and turn it off.
My guess is that I will never need to touch the button, so I will just get whatever I can find
Cheers!
2011 FPV F6 Auto
