07-06-2019, 08:35 PM | #1 | ||
Hi,
I’ve currently got a planning permit in to build a 13m x 7.5m shed with 3m eave height. I’ve had a few different ideas of what size roller doors and placement of roller door to maximise its full potential. I want to have a workshop with mezzanine above and be able to store carpentry trailer, caravan (maybe a boat one day too. My though was to have two roller doors on the long side and 1 in the gable side as well but I’m interested in different ideas. So please help me with anything you have or know anything or pictures of your own shed. Regards Deven |
07-06-2019, 09:58 PM | #2 | ||
My 2 cents worth, is; You're Shed's not High enough..
Most Caravans particularly if fitted with a roof mounted Air conditioner will be higher than 3 Metres.. At the very least make the Door in the Gable end a Slider or Swing so as to get the opening higher than 3 Metres.. |
2 users like this post: |
07-06-2019, 11:54 PM | #3 | |||
RPO 77
I think your shed is too small for what you want to do with it 4x3m bay = each bay may be too small/skinny with all items in there 3x4m bay = not enough bays for the toys because workshop/mezz will take up a bay the knee/eave height will/can work with the right roof pitch to create the height required for the caravan - you only need 400mm head room above DLO for a roller i do think you need to go a little bigger - perhaps 16x7.5/8 for what you want to do - 13x7.5m will be fine without the boat 2no 3.0m (w) x 2.6m (h) rollers to side wall for the open bays and a 3.0m (w) x 3.0m (h) to the gable end wall opposite the workshop/mezz?
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced? A: It is over priced - just like all the other falcon coupes for sale!! |
08-06-2019, 02:47 PM | #4 | ||
Cabover nut
American barn would give you the mezz and higher centre door height.
08-06-2019, 03:12 PM | #5 | ||
You will need at least 4m for each bay's width.
12-06-2019, 07:14 PM | #6 | ||
Depending on the zoning, what's 300mm between friends?
Or was it a typo: you meant 13×17.5m? ;-) To put it into Ford context you need working bays large enough to remove or hang a Mustang door on the body, or enough space to wheel a crane with a 351 past the hoist post. Max out the roof pitch, is it a portal frame, a trussed roof or cut timber? 39° (10/12) is a traditional pitch for older Australia roofs but now needs engineering rather than use of the BCA/TFC. |
