Old 17-12-2019, 07:41 PM   #1
Default Now this IS the worse Milkshake I've Seen
https://www.facebook.com/9to5life/vi...3137117117909/
Apparently engine oil and coolant.
Old 17-12-2019, 07:53 PM   #2
Rob S
Default Re: Now this IS the worse Milkshake I've Seen
Do you know what kind of car and how long it sat,and environmental factors etc?
Rob.
Rob S is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2019, 08:17 PM   #3
Don't know but some of the comments suggest it apparently was a used engine that had been installed as a replacement from a wreckers and the engine had been sitting at the scrapyard with coolant in the oil for some years; initially ran but then would not start.
Old 17-12-2019, 08:26 PM   #4
Some other cases though:
https://www.youtube.com/watch?v=D3Q4FBKrNYY
https://www.youtube.com/watch?v=cGM9EhQn4tg and https://www.youtube.com/watch?v=xj5Kn8IyiC8
Perhaps these ones are jokes; I am suspicious but I don't know for sure. He says it's not a joke at https://www.youtube.com/user/MrJooksing/videos and test showed no coolant in the oil but he did leave the same oil in for 8 years in a place that gets sub-zero F temperatures.
Old 17-12-2019, 10:51 PM   #5
Rob S
And I thought M1 was supposed to be good,nah probably is but that stuff ain't too fresh.
Rob.
2003 BA Futura.
Former Ford's.
1978 XC V8 Fairmont.
1977 XC 4.1 Crossflow Falcon.
Last edited by Rob S; 17-12-2019 at 10:56 PM. Reason: Trying to figure this signature thing out,got it wrong before,thought it was for profile page.
Old 18-12-2019, 01:45 PM   #6
Vesper Martini
Vesper Martini's Avatar
Apparently thats what happens when coolant get mixed with oil, But it would have to sit for a while. so scrapyard engine story ads up - except surely you would check the oid before installing in the car
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2019, 04:44 PM   #7
Vesper Martini
*oil before installing it in the car
Old 18-12-2019, 06:03 PM   #8
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
That jelly looking stuff is way to clean and uniform. When it's pulled away from the engine the underlying metal is spotless.
No way that is simply sump oil sitting around for ages!
Old 19-12-2019, 05:32 AM   #9
GASWAGON
Hmm seems a bit suss to me ive seen water in engine oil a few times and it does'nt do this the engine oil just turns nearly white.
Drain, change filter and flush a few times with cheap oil, then fit good oiil when most of water is removed.
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2019, 06:20 PM   #10
jaydee
jaydee's Avatar
Looks more like someone has put a bit too much additive of some sort to stop oil leaks.
The oil has then congealed.
jaydee351
4DV8
jaydee is online now   Reply With Quote Multi-Quote with this Post
Old 19-12-2019, 07:45 PM   #11
styxs
styxs's Avatar
This idea I can get behind. +1
styxs is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2019, 08:14 PM   #12
See https://www.thedrive.com/news/31362/...e-on-a-wrecker
Others chimed in to suggest that this mixture can become solid like in the video if the engine also overheats, evaporating all of the water content from the disastrous concoction. The heat then solidifies the remaining chemicals left behind—such as propylene glycol or ethylene glycol, both active ingredients in most antifreeze and coolants. Propylene glycol can become gelatinous under extreme heat conditions since it's also used as an emulsifying agent.
