Old 24-08-2020, 07:26 PM   #1
car10002
Default Chassis number question
Hi everyone
For a old 60s/70s viscount van that still has rego plate but doesn’t have chassis number or the rego paper can’t be found how would you go about getting the chassis number or a replacement chassis number for the old rego number on the van if particular one hasent been registered in a lot of years
Can you just make up your own chassis number for the rego number or get a vin number for it or is there a way to get hold of the chassis number for it if it has one
Thanks
car10002 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2020, 07:47 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Chassis number question
Your best bet would be to contact your local Dept of Transport or Police station.
Old 24-08-2020, 09:08 PM   #3
car10002
If getting new vin and rego no and id check can you name it as viscount or millard or franklin whatever it is originally or does it have to be homemade in the make section of mr1
Old 24-08-2020, 09:23 PM   #4
leesa
That's probably a question for the police but in my case i applied for a new vin for a car and the paperwork stated the model it was, it wasn't labelled homemade.
You'll probably need to take it to a local police station for inspection and then the police will issue you with a new vin which you'll then need to get stamped on the chassis. the transport department and police department will communicate with each other to book it in.
Old 24-08-2020, 09:30 PM   #5
car10002
What’s steps to new vin and rego on vans do know in sa for trailers it’s
Get vin and put on id plate then on trailer
Get permit
Go to weigh bridge
Go to police for id check
Register
