Old 13-01-2021, 12:07 PM   #1
BlueEA
BlueEA's Avatar
Default Recommendation for high temp paint
Hi all,
I hope you all had a great Xmas & wish you all the best for the New Year.
I'm in the midst of a number of various resto's at the moment. A few of them being ride on mowers and I'm having an issue with heavy surface rust on the muffler/exhaust so I'm trying to locate a high temperature paint for the exhaust manifold & muffler. Prior to now the high temp paint that I've been using is not up to the task just basically falls off when it gets hot & I don't want to go ceramic coating although it would probably be the best option but given that I have a few to do it would be a bit too costly. Surely there is something out there that could handle said task. I'm also still trying to find a way to quieten them down. I know it's a big ask but any recommendations from experience would be greatly appreciated.
Grahame.
BlueEA is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2021, 01:17 PM   #2
ute83
Default Re: Recommendation for high temp paint
I've used por15 paint with success.
ute83 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2021, 01:42 PM   #3
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Surely an engine block paint would work??
Sent from my SM-G973F using Tapatalk
___________________________
Old 13-01-2021, 01:58 PM   #4
66FAIRLANE
66FAIRLANE's Avatar
I like the Rustoleum high heat range.
66FAIRLANE is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2021, 08:33 PM   #5
xr8-200
xr8-200's Avatar
I used a spray can of pot belly stove paint on the exhaust of my old race car and it turned out pretty good.
xr8-200 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2021, 01:45 AM   #6
BlueEA
BlueEA's Avatar
Thank you to those who responded much appreciated.
Ute83= Don't know that one but thanks for the heads up I'll keep it in mind.
Yellow Festiva = You'd think so, but although the engine block can get very hot at times it doesn't reach the temperature of an exhaust/manifold that can throw out some serious heat. Just like most paints eng-blk paint is application pacific.
66Fairlane= I haven't tried that but have heard of good results from it so I'll see how I go with some other products recommended to me.
Xr8-200= I have actually used that and it was pretty good but on these jobs that I have lined up require a different color, like an ceramic aluminium look.
