Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 12-12-2021, 07:27 PM   #1
NCII40
XR6T BA 2002
NCII40's Avatar
Default Re: Twin piston 355mm brake kit
Will the C5 corvette front brakes work ? i was gonna import some from the states
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2021, 09:40 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Should be ok but you would have to make brackets for them. Just make sure they fit the correct thickness rotor you are going to use as well.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
FLOORED is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2021, 09:55 PM   #3
383hq
If memory serves correctly, PBR (vic) made them for C5, essentially same as the HSV, and were for 32mm thick rotors - if correct, this might help if you find some locally (and save you time linishing "Corvette" off the casting)
383hq is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2021, 09:28 AM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
They did make them for HSV but also Toyota along with Ford. The rotor sizes varied but were all 32mm thick as you mentioned but they all had a different mounting cradle to suit the different offsets and rotor diameters. They no longer make this caliper and are very hard to find unfortunately.
MATTHEW PEARCE
Phone 02 9609 1101
Old 28-02-2022, 12:39 AM   #5
NCII40
XR6T BA 2002
NCII40's Avatar
Found a set of PBR blues
Legend Cheers for helping out
Just need these brackets to fit 355mm discs now
XR6T 2002 BA
