Old 28-07-2022, 12:03 PM   #1
Vesper Martini
Vesper Martini's Avatar
Default 66 Mustang brakes
Im helping a mate do a few mods on a pretty basic 66 Mustang. 289 auto
currently it has a small booster maybe 5" and single pot master Cylinder. the booster is stuffed at the moment I assume it would need a new diaphragm
But we were looking to replace it with a 7" booster and better Master cylinder.
I've seen a few kits at quite high prices or overseas needing shipment.
what can anybody suggest? is there one from a later model Falcon that would do the job?
cheers
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2022, 12:50 PM   #2
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: 66 Mustang brakes
Ask Matt from Race Brakes Sydney in the sponsors section of the forum.
He may be able to help.
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2022, 09:42 AM   #3
Rob993
Rob993's Avatar
Default Re: 66 Mustang brakes
Hi,
what is the brake configuration drum/Drum or Disc/Drum?
These are light cars - can easily use a manual setup.
If Disc/Drum i would change to a dual pot master cylinder for safety such as MC36440
https://www.amazon.com.au/Raybestos-.../dp/B000C71J92
That is what i did on my 65- I am quite happy with the braking . Slightly harder pedal .
cheers
Rob
65 FASTBACK-
Rob993 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2022, 10:13 AM   #4
Vesper Martini
Originally Posted by Rob993 View Post
Hi,
cheers
Rob
Thanks Rob,
It has discs on the front and the rear drums now work, as the adjusters were slipping initially.
what booster are you running, Im conscious of not getting something that extends too far and touching the strut brace
Old 29-07-2022, 10:21 AM   #5
Rob993
Rob993's Avatar
Hi,
no booster- manual brakes.
Correct there is not alot of room to run a booster and a dual master cylinder though there are kits available from local mustang parts vendors.
Rob
65 FASTBACK-
Old 01-08-2022, 12:52 PM   #6
I don’t have an early Falcon these days, so can’t look under the dash - it was similar dimensions to a Mustang - but what about a booster inside the cabin? I think RRS offered something like that.
Old 01-08-2022, 01:05 PM   #7
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
How about a remote booster, I Know the VH44 was for drum brakes and the VH40 was for disk and drum
https://www.ebay.com.au/itm/32528291...frcectupt=true
prktkljokr is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2022, 02:08 PM   #8
Vesper Martini
There are a few kits around with Boosters to fit under the bonnet, I was hoping to make it a bit easier to source by using Falcon parts a friend said they fitted an XW booster, but it seems the falcon have become just as scarce & expensive
Im looking at this, just need to confirm if its 7"
https://mustangautoparts.com.au/coll...st-mastr-64-66
