Old 10-10-2024, 10:54 PM   #1
Tonz
Default dash mats
how are dash mats made?
Is it from basic material and a spray starch (Something your mother used on your sunday best shirts = stiff collar)
or
or
Ive added a sun visor to my ICC screen and its put the existing dash mount out of alignment....so I thought it easier to design something from paper/cardboard then copy onto upholstery material then 'process' it so it stays in shape
Old 10-10-2024, 11:47 PM   #2
Default Re: dash mats
I believe they’re slumped over a form by use of heat or hot air.
Starch… Did you hear about the Scotsman who confused his starch and baking powder?
Old 11-10-2024, 12:42 AM   #3
swamp
hi
Same way molded carpets are done .
swamp is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2024, 10:14 AM   #4
BFIIGhiaZF6
George
BFIIGhiaZF6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: The experience, information and willingness to help and share data in regards to the ZF cooling system options has probably cleared a lot of doubt about air/oil coolers and the ZF transmission.
Same as a Toupee, and looking just as bad:, why would you cover up a perfectly good looking dash?
Got a pic of the ICC sun visor Tonz, now that sounds like a good idea:
BFWSM
https://www.fordforums.com.au/vbport...articleid=1708
http://fordforums.com.au/wsmpub/ba/501-05.html
2007 BFII Fairmont Ghia I6 4L, ZF6 Auto, Ego Charcoal, Warm Charcoal.
R/U 2019:Winner 2023 2025:, Best BA-BF Geelong AFD.
PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI.
1997 Fairmont EL Ghia Tickford 4L Auto
1985 Falcon XF GL 4.1L Auto.
1979 Fairmont XD Ghia 4.1L Auto.
1971 Cortina GL Estate Manual.
BFIIGhiaZF6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2024, 02:28 PM   #5
Tonz
Because I dont protect my ute the same way as you matey. and I prefer them to the suns reflection in my eyes.
This is the 'visor' I mentioned. May look a little agricultural but it does what I hoped it would.
Took several attempts with firm cardboard then some 1.6mm galv sheet metal bent and folded in the right places, some cheap carpet type stuff and it simply pushes into the gap between the dash and the screen.
Old 14-10-2024, 04:34 PM   #6
mad2
Regular...with metamusal
mum has something similar with her car.. no it's not a ford.
Old 14-10-2024, 08:59 PM   #7
Itsme
Itsme's Avatar
Have tried to sit & attach your homemade visor on top the existing mat?
Old 14-10-2024, 09:18 PM   #8
Tonz
that will be my last attack. Ive emailed the 3 better manufacturers of dash mats to see if they would do a one off from my measurements or what suggestions they can offer.
Theres a couple of DIYs on YTube that have grounds for thinking over.
Old 15-10-2024, 09:00 AM   #9
b0son
Joinery in a car ... it's like a bad Top Gear challenge.
b0son is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2024, 10:18 AM   #10
I think the idea is sound, Tonz do you have a heat gun? Buy a scrap dash mat and experiment with slumping it over a form.
If you can get it to mould suitably, maybe have the piece overlocked and then slip it under your existing mat (which you would cut out and also overlock).
