Old 07-11-2024, 02:58 PM   #1
Jakus333
Exclamation 04 ba xr6 wiring problem/won't start
Hi I recently bought a 04 xr6 ute that had a front driver's tyre blow out and somehow ripped the wiring loom out of the cabin and shredded the whole lot. So I bought a whole new wiring loom including fuse box in engine and everything lights up but engine won't kick over. Then I noticed the stereo has no power nor does the aircon or the interior lights or the windows and the original cluster gauges were stuck half way with or w/out power so I replaced that I also replaced the iss bcm and ignition all from the same vehicle and it hasn't changed anything lights are on but no1 home can any 1 please help point me in the right direction
Jakus333 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2024, 04:39 PM   #2
X-AHH
The good, bad and fugly
X-AHH's Avatar
Default Re: 04 ba xr6 wiring problem/won't start
Considering that you have more than 1 item without power, one of the main fuses might have blown during the initial damage event. Check all fuses 30A and above.
Refer here.
https://fordforums.com.au/wsm/wire/ba74/Wiring4.html
Time was on my side!
X-AHH is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2024, 12:26 PM   #3
What year/model was the harness donor? It’s possible (for example) that you have installed a BF front right harness. It will fit but won’t work.
Old 08-11-2024, 12:36 PM   #4
See https://fordforums.com.au/vbportal/v...?articleid=497 and https://www.startmycar.com/ford/falc...o/fusebox/2004 and check the Main and Battery Fusible Links.
