Old 18-02-2025, 03:15 PM   #31
Default Re: JH Cruze 1.8 Knock
Not yet! The fellow wants it if the knock does a Franco. Half the parts aren’t ordered yet, the rest are in transit.
Old 24-02-2025, 04:23 PM   #32
Originally Posted by lra View Post
Holden service centres still exist, AKA AC/Delco, and sometimes are cheaper than other outlets.
Suttons have been good to me for the stretch bolts on cam, crank; only waiting on the cambelt kit (Matsumo) to arrive now.
Next weekend should see if the knock knocks off or if the knockers’ knocking rings a bell.
Old 02-03-2025, 05:07 PM   #33
What’s the collective wisdom on sleeving a gouge like this? Inlet cam variator.
That’s my oil leak. The knock was timing belt tensioner slapping about - belt was oil soaked and elongated.
Old 02-03-2025, 05:13 PM   #34
smoo
smoo's Avatar
Thread locker like loctite 243 around the end of the gear, will fill up that gouge as the sleeve goes over it.
smoo is online now   Reply With Quote Multi-Quote with this Post
Old 02-03-2025, 05:25 PM   #35
roKWiz
Cabover nut
roKWiz's Avatar
They tried filling a gouge, then later sleeving it on one of my Trader's rear main, didn't work.
Old 02-03-2025, 06:31 PM   #36
smoo
smoo's Avatar
The sleeve should seal by itself as it’s a press fit.
Thread locker should also seal on the backside of the sleeve, building up a film as it is pressed on.
Old 02-03-2025, 07:50 PM   #37
After wiping down the sprockets, this one has a “rattle of death” when shaken, so I think it’s burgered anyway.
Old 02-03-2025, 09:48 PM   #38
Has anyone here, the Holden part numbers for Cruze F18D4 cam sprockets, please?
The GM part numbers of 55567048, 55567049 aren’t recognised by Suttons’ web store.
Old 03-03-2025, 10:21 AM   #39
roKWiz
Cabover nut
roKWiz's Avatar
Yes it should but didn't. Third time lucky, they ended up modifying the bolt on rear main seal "frame" which brought the seal lip closer to the block and off the wear line which worked a treat.
Trader's (Perkins) have high crankcase pressure and why they could easily push oil past dodgy seal fixes, probably why they were still vented to atmosphere right up to the late 90's on these trucks.
Old 03-03-2025, 12:02 PM   #40
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
If you are after them in a genuine box then Suttons may not have them, they may have them from these suppliers instead
https://www.google.com/search?q=5556...hrome&ie=UTF-8
https://www.ebay.com.au/itm/39594748...YaAg0aEALw_wcB
prktkljokr is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2025, 12:29 PM   #41
Suttons were quick to respond; $640 up front please.
I found a discrepancy in the online part numbers for inlet sprockets, mine (faulty one) is actually 55568386. That’s what is being quoted by Suttons. The other number might run with a different PCM or strategy. All exhaust sprockets share the same part number.
Old 03-03-2025, 12:51 PM   #42
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Seeing its a Flip car is it worth taking $640 off the profit when a $135 set will do the same job
I have found most suppliers have 2 part numbers for that same sprocket, 55567048 55568386
https://www.ebay.com.au/itm/18694977...EaAk_bEALw_wcB
Old 03-03-2025, 01:17 PM   #43
There’s a Korean workshop three doors down with a cooked Ashtray, think the same motor. Can’t see overheating killing the variators. He’ll likely be cheap.
Old 03-03-2025, 04:30 PM   #44
I was wrong about the Astra, it’s a different donk.
Seems the inlet sprocket changed in 2013 with the older type being the US part number, which is what most of the Chinese-in-Australia sellers are offering. One buyer said in their feedback it wasn’t compatible with their JH Cruze.
Wreckers want to sell me a whole head, nobody is parting out a damaged motor more specifically.
Old 03-03-2025, 06:35 PM   #45
Itsme
Itsme's Avatar
Are you starting to realise why the car was cheap? when it comes to sourcing parts.
Old 03-03-2025, 07:21 PM   #46
It’s a combination of Australia Tax and my impatience, I don’t want the car on three legs in my driveway for eons while I wait for a local part of unknown durability at the right price. One backyard wrecker in Campbelltown is yet to get back to me.
$640.35 from Sutton’s, is not the right price.
Tasca Parts (probably comparable with the parts side of the Adelaide Group) will sell me a genuine one for AUD295 delivered this week by courier, or I can buy surplus stock off a US Fleabayer for about AUD220 delivered in a fortnight or so. That’s the option I’m leaning towards; I can detail up the rest while waiting.
Old 04-03-2025, 05:51 PM   #47
nearlythere
END WOKENESS
nearlythere's Avatar
Gimmi 10 bucks and i'll dispose of it for you.
nearlythere is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2025, 06:02 PM   #48
2014 is an almost new car in Tas.
Sprocket on its way for $190 (new, Dorman brand, confirmed to fit).
Old 05-03-2025, 01:27 PM   #49
ute83
I see you have a part ordered already, but have you got an imlachs wreckers around or the like. I have seen engines stripped and still in the cars.
ute83 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2025, 04:15 PM   #50
Unfortunately, no self serve wreckers near Sydney any more, it’s a rolling inconvenience.
Old 25-03-2025, 12:23 PM   #51
Only taken a bit over three weeks, but a new variator sprocket is due to arrive today. Hope to have this car on the road, knock-free, by the weekend.
Old 26-03-2025, 06:29 PM   #52
Amusement.
Original (failed) variator hub:
Dorman-boxed new part:
So the Dorman part 918-777 is a repackaged genuine GM (Chinese made) 55568386 part.
Irritation is deserved for the convoluted delivery via Fleabay’s “Expedited International Shipping” (EIS) which saw it sit in Australia for twelve days between arrival and delivery. This fiasco cost around $190 bought and delivered. I could buy another one from RockAuto and have it delivered next Monday for $120 inclusive. Another lesson learned.
Next hurdle is to buy and butcher a 15/16” open-ender (or combination spanner) for service as a cam counterhold tool. It’s timed up, but the angle torque setting is too great for the cam indexing plate to hold by itself.
Old 03-04-2025, 08:10 PM   #53
Back together and driving. Initially had a timing mismatch fault code of P0016.
Swarf from (I believe) variator failure, had heavily blocked the intake cam solenoid. It was removed, dismantled, cleaned out - the fine screens disintegrated - and refitted after briefly cranking the engine to flush out extra swarf so much as practicable (oil everywhere, just after I’d degreased it all!).
Fault code now gone. I think the solenoids are on the discharge side of the variator hubs (hence the swarf) and when the solenoid was jammed from debris it caused a mismatch of timing signals. Ominously there was also a little swarf on the exhaust cam side.
I think also the transmission is not 100% - it’s a bit iffy but no stored codes - going to try a full drop/fill with attention to the oil level. If anyone has experience with the 6T30 or 6T40 boxes re oil level, I’m interested to hear your thoughts.
Old 09-04-2025, 10:59 AM   #54
Have put about 400km on the repaired car now, not many concerns remaining. Possibly a dry intermediate driveshaft bearing.
Old 09-04-2025, 02:59 PM   #55
Sprintey
Sprintey's Avatar
Great thread to read CB, always interesting to follow the troubleshooting and see all the potential culprit parts. MIL has the same model, and tbh it's quite a nice car, seats are a bit hard but does everything else she would want well, 52 thousand km.
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2025, 06:37 PM   #56
Will probably do the trans fluid tonight, likely its first time changed. Only gripe was work had barely five litres in the LV ATF drum so as a foreign order I was effectively forced to buy a new drum - $215 for Penrite.
Floor mats due tomorrow. I’ve further noticed a pea size bullseye on the screen, not sure if I’ll bother with that. It’s not so in-your-face as the dents.
The failed variator cut open. It had an entire hard alloy shell inside the casing to seal the rotor vanes against, which cracked, ultimately shredding itself into varying sizes of swarf and debris.
Old 10-04-2025, 10:37 PM   #57
This car should have a name.
I think Nicholas, Tom or Penelope is a little too obvious.
My senior workmate has almost got into my ear about the un-replaced exhaust sprocket. If I follow his suggestion it’s another $450 plus my time…
Old 10-04-2025, 11:25 PM   #58
smoo
smoo's Avatar
You are deep enough into this you’re gonna have to keep it.
Old 10-04-2025, 11:28 PM   #59
Nope, I can’t wait for it to be gone. All I’d like besides cash is the odd message from whoever buys it, that they’re getting their money’s worth.
Old 11-04-2025, 09:55 AM   #60
roKWiz
Cabover nut
roKWiz's Avatar
Nelly..........thank me later.
