Ran 12.4 radial tyres 3.25 ratio full street exhaust toploader 2.1 first sixty was wondering what i would pick up with 3.7 ratio and slicks.
Hmmmmm Mulberry....
3.7 will pick up a bit, If you were wheel spinning (assuming you were) then slicks will help.
The only downside to slicks is they tend to drag the engine down a bit. But saying that, if you are running 12.4, then i'd say your engine is very healthy. Where did you run this time and what MPH?? |
#3 | |||
Two > One
113 with a good solid 1.8sec 60 should see 11.8
#5 | |||
Hmmmmm Mulberry....
I run 11.7 at 115 1.75 60ft on a slick tyre
But have run 11.57 at 115 with a 1.65 60 ft. First 60ft makes a lot of difference. |
#7 | |||
XA GT
--------------------------------------------------- XA GT, 6.848sec 1/8 mile @ 101.68mph |
378 cubes
air gap intake small port 3vs cam tech solid 588 lift 240 @ 50 nothing over the top 10:1 comp 6inch eagle rods Aeries pistons 0 deck shift light set at 6500 ice ignition ![]() ![]() |
#9 | |||
The Fun Mobile
I'm with walkinshaw, around 11.8. My old 351 went 1.70 sixty foot, with 11.9 at 112.78. Still, nice results mate.
408 cube Cleveland TFC @ AFD 2V, 750 DP 10.7 @ 125 mph 2V powahhhhh |
Car weight 1600kg with driver (1400 without!!!!!!!!!!!)
Don't know what power this would have? |
3 Pedals R Better Than 2
Nice work mate! and with a real gearbox
![]() As mentioned, launching with slicks will drag the revs down a bit on launch, so don't be a granny or you'll stall it...especially with 3.25's!! Get your right foot into it and go hard!! Lotsa revs is a good thing!!! That being said, high rev clutch dumps with tall gearing and slicks won't do your clutch any favours, so I'd wait for the lower diff gears. Car setup doesn't always effect the mph too much...you can have a much quicker ET but run the same mph. Basically, setup determines how quick you get off the line and engine power determines how fast you are at the other end. Bit hard to get your head around that at first. |
#12 | |||
N/A BOSS 390+
![]() ![]() FPV GT 03 /341 RWKW OF N/A POWER. XB GT 73 /OLD FORD MUSCLE ALL AUSSIE MUSCLE |
#13 | |||
Two > One
#14 | |||
![]() Quote:
