Old 14-08-2007, 09:29 PM   #1
FS5
Default cam question????
what effect do the lobe centres have on a cam?
as in do they have something to do whith what rpm a motor makes its power ?
do they have something to do with how much duration a cam has,or how much duration you can get ?
is a smaller gergree lobe centre better ?if so why ?
thanks for your help ,
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2007, 10:12 PM   #2
opto
Lobe centres are the peak point of the cam lobe.
Lobe centres are points to determine the lobe separation angle between 2 lobes on a cam inlet and exhaust.
The wider the lobe separation, generally give you a wide band of torque, with maybe some loss in peak power.
A tight Lobe Separation Angle will give you a peak power at a certain point relative to advance and retard of the cam, also some torque losses.
The tradeoff in tight LSA is less of Dynamic compression ratio with long durations at high RPM.
A tighter LSA is good for quick accelleration and high RPM operation say like speedway and drags.
Read some books on cams, alot of them are on V8's and may or may not be directly applicable to I6's.
Originally Posted by XCPWSF
Is there portable speed cameras? Because coming home from school I noticed a cop sitting on the corner, with some box with buttons and knobs, with wires running into one of the big gum trees.
Just practicing with the Tazer on a Koala?
opto is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 02:03 PM   #3
FS5
thanks mate
