Old 08-05-2012, 04:31 PM   #1
poppa smurf
poppa smurf's Avatar
Default noisy serpentine drive belt!!
any suggestions on what to spray on a noisy belt......damn thing makes all sorts of weird noises
I put some "belt conditioner" on it but thats seems to be a short term fix
looking at replacing it if I cant keep it quiet.......ideas please!!!
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2012, 05:04 PM   #2
Xr693
Default Re: noisy serpentine drive belt!!
Get a lube stick or just replace it, they're not that pricey
Xr693 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2012, 05:20 PM   #3
xisled
Just replace the thing. Will save your ears.
xisled is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2012, 07:03 PM   #4
Peter B - CV8
Whilst the motor is idling, get a candle & allow it to (carefully) rub against both the inner & outer face of the belt. Don't use soap or any other product that gets slippery if wet (apologies to Bon Jovi).
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2012, 07:12 PM   #5
mik
mik's Avatar
a smear of rubber grease usually does the trick, just put a tiny amount on !
Old 08-05-2012, 07:20 PM   #6
Rambunctious
Quick spray of WD40 or RP7
Rambunctious is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2012, 07:26 PM   #7
BHDOGS
A dash of lavender oil and a chocolate biccy
Old 08-05-2012, 10:47 PM   #8
GCRXR6
GCRXR6's Avatar
errr in the words of Pauline ... "Please explain?"
Might smell pretty ... but ???
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better!
GCRXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2012, 10:07 AM   #9
poppa smurf
a very poor attempt at, what he see's as, humour!
thanks for the replies, much appreciated.....as i get time I will work down the list......one must work surely
Mik where would I get the rubber grease and can I use it on other things such as stabiliser bar rubbers and shocker mounts
Old 09-05-2012, 11:11 AM   #10
poppa smurf
worked a treat.....thanks.....another benefit that I have is that until I used the candle I didn't realise it was "scented"
I now have the sweetest smelling under bonnet of any vehicle I know
jasmine I believe!!!........flower power is NOT dead!!!
Old 09-05-2012, 02:44 PM   #11
BigBlue
poppa smurf,
Rubber grease is available from the usual places...Repco , Autobahn etc.
Usually comes in a tube about 250 grammes from memory.
Haven't bought any for ages.
Peter.
BigBlue is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2012, 02:47 PM   #12
poppa smurf
Originally Posted by BigBlue
poppa smurf,
Peter.
thanks Pete.....looked it up and yep......readily available...I had never heard of it before.....I can see a lot of uses for it when on the road!
Old 09-05-2012, 10:51 PM   #13
mik
mik's Avatar
it`s handy stuff , comes in most popular sizes.
Old 10-05-2012, 12:44 AM   #14
Werd.
nou
Replace the belt! lol takes $20 and 5 minutes.
If you don't know how, cut it just before a caravan park and limp your car over out front, pop the hood and look confused, one of em will help out for a 20 or a slab of beer.
Werd. is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2012, 06:31 PM   #15
graham7773
I know everybody (with one or 2 exceptions) is trying to help but why would you put a lubricant on a drive belt when it needs grip to work properly? Just pull the belt off, turn it inside out and check for cracks or splits. If you find them, there is the cause of your noise. Replace. While the belt is off, check the tensioner and idler pullies for noise. Usually a mild grumble or squeal. Replace. Also check your water pump for free turning and play. Free turning is ok, play is not. While you are there, again, make sure the water pump spindle is not making any noise as well. I had one sieze on me and cost me a new pump and belt plus was finding bits of destroyed serpentine belt for months after all around the engine bay. Hope this helps.
I forgot to mention, alternators can make noise when they are on their deathbed as can air con compressors.
graham7773 is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2012, 07:02 PM   #16
poppa smurf
I understand what you are saying but all is good mechanically, simply a noisy belt
I had my suspicions about it being something more sinister as well but as soon as I put some "belt conditioner" on it ( I use a lot of the stuff around my workshop on different machines so i know it's good gear) the noise ceased leading me to believe it is only the belt
this turned out to be a short term fix
the noise has returned after treating it yesterday with candle wax so i think it may be time for a new belt
I'll look at it on the weekend
I dont like the look of the job but easily do-able
Old 10-05-2012, 07:32 PM   #17
Werd.
nou
Mine looked mint too, squeaked for about 20,000kms until one day starting up at a petrol station it flung off and left me to drive home with no power steering, alt, water pump etc..
Old 10-05-2012, 07:57 PM   #18
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Poppa Smurf what series Falcon is it?
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 10-05-2012, 08:30 PM   #19
Werd.
nou
His sig.
Old 10-05-2012, 08:46 PM   #20
poppa smurf
late 05 BA Fairmont MII
Old 10-05-2012, 08:47 PM   #21
xrystl
xrystl's Avatar
Silicone spray works , my VW Crafter had this problem and the techs put me onto the spray while a permanent remedy was being worked on .
xrystl is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2012, 09:25 PM   #22
mik
mik's Avatar
i`m guessing your questioning the rubber grease, i don`t know scientifically what it actually does, all i know is a newish car would come in for a service , if it had a noisey belt, nothing the matter with the belt, tension ok, we`d put a smear of rubber grease on it, it would shut it up almost instantly, and as i said, you don`t put a silly amount on so it sits there doing a burnout, just a smear.
Old 11-05-2012, 11:17 AM   #23
poppa smurf
any reason why I should buy a "gates" belt at $70 odd dollars compared to normal $25 belts
longevity I assume???
