Old 10-09-2012, 06:32 PM   #1
79FordEsky
79FordEsky's Avatar
Default Car engine turned into a air compressor
Recently I have come up with the idea of building a custom air compressor,
What i was thinking is to use a v8 and then use 4 cylinders for power and the other 4 to make compressed air. I have been doing research and people have done it with v8s and volkswagen flat 4.
Just wanted to see the ideas and any tips
My Ride: -
My Survivor 1 owner XC Wagon
Check it Out
79FordEsky is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 07:52 PM   #2
EDManual
EDManual's Avatar
Default Re: Car engine turned into a air compressor
sounds interesting!
EDManual is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 07:54 PM   #3
Tomo1972
Used for?
Tomo1972 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 07:59 PM   #4
redxr8
yeah tryed that a few years ago with my 4x4 at the time,this worked to produce the air as expected but heat was a problem as was fuel in the line because it was a carb motor,i think if were using an efi motor and stop the injector on that cyl it might work ok. Iam asuming you are talking about the air line out of the plug holes, hope this helps
redxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 08:08 PM   #5
graham7773
You are going to use the V8 for a compressor using 4 cylinders for drive/power? How are you going to avoid getting fuel in the compressed air? That could be a disaster, compressing a fuel air mix. And if it is pumped into a holding tank, you will be building a bomb.
graham7773 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 08:18 PM   #6
Jim Goose
maybe thats the plan...
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 08:28 PM   #7
ebxr8240
Performance moderator
ebxr8240's Avatar
Originally Posted by Jim Goose
maybe that's the plan...
Most of them have a lion badge on them..Aha..
To use same motor ?? You would have to separate inlet to carb on compressor cylinders..
We used to have a valve that fitted on plug which pumped up tractor tyres..
Not much fuel was drawn through as air would enter via valve on screw in device.. I think the cam / valve timing would need to be different to use
as compressor using whole engine with another 4 cylinder to power it..
At our old butter factory we had two v10 compressors..
They MAY have been for air conditioning ??
Daily driver GTE FG..
Old 10-09-2012, 08:32 PM   #8
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
I'll just leave this here....
http://www.youtube.com/watch?v=S1sGzIX_mqo
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 10:57 PM   #9
79FordEsky
79FordEsky's Avatar
This is the VW kit I was talking about , you use a twin port motor and then put this kit in, then hey presto you got yourself a 58cfm@100psi http://vwparts.aircooled.net/Volks-A...R3S-p/dr3s.htm
My Ride: -
Check it Out
Old 10-09-2012, 11:04 PM   #10
2011G6E
2011G6E's Avatar
Hmmm...I've got an old 1200 VW engine sitting under my house...interesting...
2011G6E is offline   Reply With Quote Multi-Quote with this Post
