Old 20-06-2006, 03:48 PM   #1
FS5
Default diffgears / mph
do diff gears effect your mph ?
i have a set of 3.45's in my au 5spd and i will be changing them to 3.9's soon .i currently have to grab 4th gear about 50m before the line. will going from 3.45 to 3.9's increase my mph or will the mph stay the same ?
i know going s 3.9's will give me a better ET but just not sure about the mph.
thanks ,jake
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 04:30 PM   #2
Stav
Smile
Stav's Avatar
Gears will boost you off the line and reduce top end by the same amount.
Old 20-06-2006, 04:34 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
Are you sure,, mph is power I dont see how changing the diff will drop mph unless you are running out of puff before the 400m
Old 20-06-2006, 05:00 PM   #4
FS5
my peak hp comes on at 5400 rpm and i'm crossing the line @ 4400/4500 rpm in 4th
Old 20-06-2006, 05:00 PM   #5
OED666
OED666's Avatar
you will be fine... i got 4.11's, and there is no way mine slows down at the top end. i agree with tibbo, unless your running out of puff you will be fine.
3.9's are good gears. in a way i wish i got them, but only for highway cruising. you will find that your first gear with 3.9's is shorter than mine with 4.11's.
BTW, useless, have you got that nice cam in yet...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 05:04 PM   #6
Mark351
Built Ford Tough
Mark351's Avatar
Why do you need to change into 4th? I can hit the line still powering down in 3rd, and mine's also a 4spd manual with 3.45s....
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 08:13 PM   #7
Stav
Smile
Stav's Avatar
Hheeh not yet mate.I am giving this setup one last chance to see what difference the cold weather will have down the 1/4 mile.
Also I have nearly finished my super head that ive been porting and fighting with for a while.I am thinking of doing the head and cam at the same time or if I feel lazy just stick the cam in and deal with the head at a later kilometres. : .
Old 20-06-2006, 08:52 PM   #8
FS5
when it had 3.23 i used to hit the line right on the limiter ,now after fitting 3.45's i need to grab 4th .
what rims and tyres do you run ?
i run 225 /16 / 50's
Old 20-06-2006, 08:54 PM   #9
FS5
oed what gears did you run before the 4.11's ?
did you notice any difference in your trap speed after fitting the 4.11's?
Old 20-06-2006, 09:51 PM   #10
OED666
OED666's Avatar
i had 3.9's before. i didnt notice any difference in trap speed. maybe even faster now...
i spose i never really unleashed the full potential of it with 3.9's. plus i didnt have my au motor in when i had 3.9's
Turbo Barra ED 4L
Old 20-06-2006, 10:16 PM   #11
Mark351
Built Ford Tough
Mark351's Avatar
I'm running 17"s, but didn't notice any difference when I ran 15"s
Old 21-06-2006, 07:44 AM   #12
FS5
what mph are you getting when tou hit the line in 3rd ?
i have tested mine a couple of times crossing the line in 3rd and it dose around 90mph .
Old 21-06-2006, 09:31 AM   #13
Mark351
Built Ford Tough
Mark351's Avatar
Up to 95 mph, but I've got intake/exhaust mods and a great tune.
Old 21-06-2006, 09:38 AM   #14
OED666
OED666's Avatar
plus you have nice cold vic air... us qld'ers arent quite as lucky...
maybe a road trip to vic is in order... :P
Turbo Barra ED 4L
Old 21-06-2006, 04:42 PM   #15
FS5
crikey thats a bit of difference ,are you hitting the limmiter in 3rd.
considering we are both running the same gearbox and diff ratio's you wouldn't think there'd be 5mph difference running 16 inch wheels against 17's .
Old 21-06-2006, 04:52 PM   #16
Mark351
Built Ford Tough
Mark351's Avatar
I can't remember ever hitting the limiter in 3rd, and of late that's less likely to occur.
Old 21-06-2006, 05:28 PM   #17
jonbays
TL40 Wagon?
4th in your manuals is like third in our autos and even with 3.9's you should pull 5500rpm at around 28kmh/1000rpm thats 154kmh a good TS for most hot sixes.
Old 21-06-2006, 08:32 PM   #18
jonbays
TL40 Wagon?
Diff Tyres Kmh/1000rpm Speeds in gear
Ratio Third 3000-5000-5750rpm
3.08 225/50R16 36.59 110 183 210
3.23 225/50R16 34.97 105 175 201
3.45 225/50R16 32.74 98 164 188
3.73 225/50R16 30.28 91 151 174
3.89 225/50R16 29.04 87 145 167
Old 21-06-2006, 10:20 PM   #19
FS5
so 3rd in an auto is the same as 4th in a manual .
deathxr ,yours is a manual isn't it?
Old 21-06-2006, 11:51 PM   #20
Stav
Smile
Stav's Avatar
Ah stuff it I am tempted to throw it in this weekend.
Old 22-06-2006, 07:31 AM   #21
FS5
dooooooo it ya know you wanna
Old 22-06-2006, 07:31 AM   #22
Mark351
Built Ford Tough
Mark351's Avatar
Yeah, mines a manual. Just ignore the auto guys. ;)
Old 22-06-2006, 08:16 AM   #23
jonbays
TL40 Wagon?
Yes
1:1 gearing in third gear in a 4 speed BTR Auto and in 4th gear in the 5 speed manual.
Old 22-06-2006, 08:20 AM   #24
jonbays
TL40 Wagon?
Even with 4.1 gears you should never hit the rev limiter in third/fourth in the qtr. Well not unless you are genuinely getting under 13 sec ET's.
Speed limiter is differnent. In non XR models if the ecu thinks its doing 180 it will shut down the fuel. Without speedo adjustment that's maybe as low as a true 141kmh
Old 22-06-2006, 09:07 AM   #25
jonbays
TL40 Wagon?
In my opinion for drag racing with a falcon six auto or manual you want third or fourth gear respectively to take you to the line at peak power rpm leaving enough room to cross the line and just hit the rev limiter.
Now in a stock falcon or mildly modded one you will see peak power at around 4900-5000rpm and with most road going cammed cars this doesn't get much above 5250-5500rpm.
So for best drag strip performance you want to use all three or four gears fully in the qtr so for a mild car 3.73 gears are good which with 225/50R16 tyres give 30.28kmh/1000rpm and a power band from 91kmh to 151kmh and a rev limit at 174kmh.
Few mild falcons will do more than 151Kmh TS in the qtr!
For a bit of a hottie or absolute max qtr performance 3.9 gears give 29.04kmh/1000rpm and a powerband from 87kmh to 145kmh and rev limit at 167kmh.
See how well frdgal is going with 3.9's and a stallie and you see this is a good option.
I am sticking with my 3.45 gears which gives me 32.74kmh/1000rpm and a powerband from 98kmh to 164kmh with a rev limit at 188kmh. This is nice for a road car as it has nice pull in third from 100k and revs to the speed limiter before rev limiter! Also for a wagon it doesn't spin up the extra long tailshaft too much.
Old 22-06-2006, 01:19 PM   #26
FS5
3.9's will be the perfect match for my car as it is now.
i'm still interested to know if changing the gears will increase my mph ?
Old 22-06-2006, 02:01 PM   #27
OED666
OED666's Avatar
i was reading a mag recently, and these guys fitted 3.9's to a vy ss and it did picked a few mph at the end.
i am sure the gears will help overall acceleration.
Turbo Barra ED 4L
Old 22-06-2006, 08:19 PM   #28
jonbays
TL40 Wagon?
From what I can tell the lower diff gears really make a difference in the middle range.
A stallie helps out in the 60' in an auto.
The diff works well to improve the 330 and 660. 660 on the guys and girls with lower diffs than me arent making any ground on me so i don't know that the gearing will add mph to your TS. I would say they will cut tenths from the mid range 330 and 660.
Old 22-06-2006, 08:31 PM   #29
jonbays
TL40 Wagon?
here are the splits between me and useless
useless runs 3.73 diff and a hi stall converter
I run 3.45 gears and stock converter
60' 330' 660' 1000' ET
-0.1670 -0.0760 -0.0200 -0.0030 -0.0040
The big differece is the 60' and thats the hi stall
The small but significant difference in the 330 and 660 is the diff gearing
The 1000 and qtr not much difference.
you can see by the fact we both have similar modded falcon auto wagins and the similar TS MPH the cars power to weight has to be pretty close.
So the differences are the stall and gearing.
Oh and the drivers too.
