Hi everyone
For a old 60s/70s viscount van that still has rego plate but doesn’t have chassis number or the rego paper can’t be found how would you go about getting the chassis number or a replacement chassis number for the old rego number on the van if particular one hasent been registered in a lot of years Can you just make up your own chassis number for the rego number or get a vin number for it or is there a way to get hold of the chassis number for it if it has one Thanks |
Former BTIKD
![]() Join Date: Mar 2005
Your best bet would be to contact your local Dept of Transport or Police station.
If getting new vin and rego no and id check can you name it as viscount or millard or franklin whatever it is originally or does it have to be homemade in the make section of mr1
#4 | |||
You'll probably need to take it to a local police station for inspection and then the police will issue you with a new vin which you'll then need to get stamped on the chassis. the transport department and police department will communicate with each other to book it in. |
What’s steps to new vin and rego on vans do know in sa for trailers it’s
Get vin and put on id plate then on trailer Get permit Go to weigh bridge Go to police for id check Register |
